06-14-2004 04:58 PM - edited 03-09-2019 07:44 AM
I want to update a pix520 firewall from 4.2.4 to 6.0.
The follow error message:
fw2#
Finesse Bios V3.3
Booting Floppy
...................................Execing flop
Cisco Secure PIX Firewall floppy loader (3.0) #0: Tue Sep 11 07:34:46 PDT 2001
Reading installation media..............
128MB RAM
mcwa i82559 Ethernet at irq 11 MAC: 00d0.b79a.1ec8
mcwa i82559 Ethernet at irq 10 MAC: 0002.b309.388b
mcwa i82559 Ethernet at irq 15 MAC: 0002.b303.e827
mcwa i82559 Ethernet at irq 9 MAC: 0002.b303.ecff
Flash=AT29C040A @ 0x300
Obsolete FLASH card. Upgrade required. See release notes for this version.
c i s c o S y s t e m s
Private Internet eXchange
Cisco PIX Boothelper
Cisco PIX Firewall Version 6.1(1)
open(ffsdev/2/read) failed
An internal error occurred. Specifically, a programming assertion was
violated. Copy the error message exactly as it appears, and get the
output of the show version command and the contents of the configuration
file. Then call your technical support representative.
assertion "fdf_init()" failed: file "bh_main.c", line 146
No thread name
(CONT.....)
06-14-2004 05:00 PM
(CONT)
Traceback:
0: 8002674d
1: 8000735b
2: 80006e57
3: 80000818
4: 80000223
vector 0x00000003
edi 0x8000731f
esi 0x00000092
ebp 0x7ffffe78
esp 0x7ffffe6c
ebx 0x80006eee
edx 0x000003fd
ecx 0x00000000
eax 0x0000003a
error code 0x80027afc
eip 0x00000008
cs 0x00000006
eflags 0x7ffffea4
CR2 0x00000000
0x7ffffeec: 0x87ed3000
0x7ffffee8: 0x0000e5e0
0x7ffffee4: 0x0000809d
0x7ffffee0: 0x0002d000
0x7ffffedc: 0x80000818
0x7ffffed8: 0x7ffffef8
0x7ffffed4: 0x00000002
0x7ffffed0: 0x00001000
0x7ffffecc: 0x00000000
0x7ffffec8: 0x8001cac0
0x7ffffec4: 0x8002e798
0x7ffffec0: 0x00000004
0x7ffffebc: 0x80006e57
0x7ffffeb8: 0x7ffffed8
0x7ffffeb4: 0x80007
0x7ffffeb0: 0x00000092
0x7ffffeac: 0x80006eee
0x7ffffea8: 0x8000735b
0x7ffffea4: 0x7ffffeb8
0x7ffffea0: 0x07fd3000
0x7ffffe9c: 0x07ff7000
0x7ffffe98: 0x8002e758
0x7ffffe94: 0x800265dc
0x7ffffe90: 0x8002666a
0x7ffffe8c: 0x00000092
0x7ffffe88: 0x80006eee
0x7ffffe84: 0x8000731f
0x7ffffe80: 0x800266ed
0x7ffffe7c: 0x8002674d
0x7ffffe78: 0x7ffffea4
0x7ffffe74: 0x00000006
0x7ffffe70: 0x00000008
0x7ffffe6c: 0x80027afc *
0x7ffffe68: 0x0000003a
0x7ffffe64: 0x00000000
0x7ffffe60: 0x000003fd
0x7ffffe5c: 0x80006eee
0x7ffffe58: 0x7
0x7ffffe54: 0x7ffffe78
0x7ffffe50: 0x00000092
0x7ffffe4c: 0x8000731f
0x7ffffe48: 0x00000003
0x7ffffe44: 0x8000395d
0x7ffffe40: 0x7ffffe78
0x7ffffe3c: 0x00000092
0x7ffffe38: 0x80006eee
0x7ffffe34: 0x00000020
0x7ffffe30: 0x8000255a
0x7ffffe2c: 0x7ffffe40
0x7ffffe28: 0x7ffffe28
0x7ffffe24: 0x7ffffe24
0x7ffffe20: 0x80001c9d
0x7ffffe1c: 0x7ffffe2c
0x7ffffe18: 0x8019000a
0x7ffffe14: 0x65687420
0x7ffffe10: 0x74656720
0x7ffffe0c: 0x646e6120
0x7ffffe08: 0x2c000a0a
0x7ffffe04: 0x2e657669
0x7ffffe00: 0x7461746e
0x7ffffdfc: 0x65736572
0x7ffffdf8: 0x70657220
0x7ffffdf4: 0x74726f70
0x7ffffdf0: 0x70757320
Rebooting....
Who can help me?
06-14-2004 05:56 PM
The current IOS:
fw2# sh ver
PIX Version 4.2(4)
Compiled on Wed 03-Mar-99 16:20 by pixbuild
fw2 up 5 secs
Hardware: SE440BX, 128 MB RAM, CPU Pentium II 349 MHz
Flash atmel @ base 0x300
0: ethernet0: address is 00d0.b79a.1ec8, irq 11
1: ethernet1: address is 0002.b309.388b, irq 10
2: ethernet2: address is 0002.b303.e827, irq 15
3: ethernet3: address is 0002.b303.ecff, irq 9
Serial Number: 18016739
fw2#
06-14-2004 10:02 PM
If your Flash memory is 2MB, u cannot upgrade your IOS to 6.0 but 5.1(4) only.
For ver 6.0 upgrade your flash card
This is the only problem I can see.
run SHOW TECH command and let me see.
Saleem
06-15-2004 12:27 AM
Thanks for you reply!!
fw2# sh tech
PIX Version 4.2(4)
fw2 up 59 secs
------------------ show config ------------------
: Saved
PIX Version 4.2(4)
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password xxxx encrypted
passwd xxxx encrypted
hostname fw2
fixup protocol ftp 21
fixup protocol http 80
fixup protocol smtp 25
fixup protocol h323 1720
fixup protocol rsh 514
fixup protocol sqlnet 1521
names
no failover
failover timeout 0:00:00
failover ip address outside 0.0.0.0
failover ip address inside 0.0.0.0
pager lines 24
no logging console
no logging monitor
logging buffered debugging
no logging trap
logging facility 20
interface ethernet0 100basetx
interface ethernet1 100basetx
ip address outside 10.122.2.246 255.255.255.0
ip address inside 10.122.3.253 255.255.255.0
arp timeout 14400
nat (inside) 0 0.0.0.0 0.0.0.0 0 0
rip outside passive
no rip outside default
rip inside passive
rip inside default
route outside 0.0.0.0 0.0.0.0 10.122.2.254 1
timeout xlate 3:00:00 conn 1:00:00 udp 0:02:00
timeout rpc 0:10:00 h323 0:05:00
timeout uauth 0:05:00 absolute
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
telnet timeout 5
mtu outside 1500
mtu inside 1500
floodguard 1
Cryptochecksum:xxxxx
(CONT....)
06-15-2004 12:31 AM
------------------ show blocks ------------------
SIZE MAX LOW CNT FAILED
4 1600 1599 1599
80 400 399 400
256 80 78 79
1550 1144 630 632
65536 8 8 8
------------------ show interface ------------------
interface ethernet0 "outside" is up, line protocol is down
Hardware is i82557 ethernet, address is 00d0.b79a.1ec8
IP address 10.122.2.246, subnet mask 255.255
MTU 1500 bytes, BW 100000 Kbit half duplex
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
0 packets output, 0 bytes, 0 underruns
interface ethernet1 "inside" is up, line protocol is down
Hardware is i82557 ethernet, address is 0002.b309.388b
IP address 10.122.3.253, subnet mask 255.255.255.0
4 packets output, 264 bytes, 0 underruns
interface ethernet2 "" is up, line protocol is down
Hardware is i82557 ethernet, address is 0002.b303.e827
IP address 127.0.0.1, subnet mask 255.255.255.255
MTU 1500 bytes, BW 10000 Kbit half duplex
interface ethernet3 "" is up, line protocol is down
Hardware is i82557 ethernet, address is 0002.b303.ecff
06-15-2004 12:34 AM
(CONT..)
------------------ show process ------------------
PC SP STATE Runtime SBASE Stack Process
Lsi 80014a16 8042bcc8 80117d58 0 8042ad08 4008/4096 arp_timer
Lsi 80016bbe 804f7bac 80117d58 0 804f6bf8 3996/4096 route_timer
Msi 8001f2aa 8059de94 80117d58 0 8059cee0 3996/4096 clean_frags
Lsi 8002aa36 805a0840 80117d58 10 8059f880 4004/4096 xlate clean
Lsi 8002a9c4 805a1848 80117d58 0 805a0888 4008/4096 uxlate clean
Lsi 8002aa95 805a2850 80117d58 0 805a1890 4008/4096 perfmon
Lwe 80028a3c 80a3fd24 80120870 0 80a3ee60 3764/4096 pix/trace
Lwe 80028c30 80a40d2c 80122200 0 80a3fe68 3764/4096 pix/tconsole
Hwe 80012d4b 80a41e14 8038bf94 0 80a40e70 3348/4096 pix/inside
Hwe 80012d4b 80a42e20 8038bf50 0 80a41e78 3488/4096 pix/outside
Hwe 80012d4b 80a43e38 8038bf0c 0 80a42e90 3488/4096 pix/2
Hwe 80012d4b 80a44e50 8038bec8 10 80a43ea8 1512/4096 pix/3
L* 800069b3 7fffff9c 80117f50 30 80a45eb8 5640/8192 ci/console
Hwe 8001ae23 80aa3098 800819dc 0 80aa2170 3864/4096 uauth1
Hwe 8001ae23 80aa40a0 800819cc 0 80aa3178 3864/4096 uauth0
Hwe 8001ae23 80aa50a8 800819ec 0 80aa4180 3864/4096 uauth2
Hwe 8001ae23 80aa60b0 800819fc 0 80aa5188 3864/4096 uauth3
Hwe 8005036f 80aa70e8 80592afc 0 80aa6190 3912/4096 uauth
Hwe 80065d15 80aa8154 80116a00 0 80aa7198 4012/4096 udp_timer
Hsi 8001020c 80aad1c4 80117d58 0 80aac208 4004/4096 557mcfix
Crd 800101cc 80aae1e4 80117f40 1
Lsi 80010222 80aaf1d4 80117d58 0 80aae218 3964/4096 557timeroppy set
Loading from Flash
(CONT...)
06-15-2004 12:37 AM
(CONT...)
Hwe 800513d4 80ab21f0 80116788 0 80ab1230 3996/4096 tcp_fast0a42e90 3488/4096 pix/2
Hwe 8005135e 80ab31f8 80116788 0 80ab2238 3996/4096 tcp_slow8 1512/4096 pix/3
Hwe 80012d73 80ab41dc 804fef90 0 80ab3240 3980/4096 fover_ip/8192 ci/console
Cwe 80011603 80ab51c4 8023ad3c 0 80ab4248 3948/4096 ip/1:1
Hwe 80012d73 80ab61f4 804fef68 0 80ab5250 3988/4096 icmp10
Hwe 80065ada 80ab71ec 801b8b8c 0 80ab6258 3972/4096 riprx1h2
Hsi 800487be 80ab8214 80117d58 0 80ab7260 3660/4096 riptx1h3
Hwe 80012d73 80ab9204 804fef40 0 80ab8268 3980/4096 udp_thread
Hwe 800
Hwe 80012d73 80aba1f4 804fef18 0 80ab9270 3956/4096 tcp_thread
Hsi 80010
Hwe 8005052e 80aba590 80582a04 0 80aba278 608/1024 listen/telnet
Crd 800101cc 80aae1
Crd 800101cc 80aae1
Hwe 80012d73 80abea44 804feec8 0 80abdaa0 3988/4096 icmp0
Hwe 80065ada 80abfa3c 801b8b4c 0 80abeaa8 3972/4096 riprx0
Hsi 800487be 80ac0a64 80117d58 0 80abfab0 3976/4096 riptx0
Hwe 80012d73 80ac1a54 804feea0 0 80ac0ab8 3980/4096 udp_thread
Hwe 80012d73 80ac2a44 804fee78 0 80ac1ac0 3956/4096 tcp_thread
Hwe 80012d73 80ac3a64 804fee50 0 80ac2ac8 3980/4096 fover_ip
Cwe 80011603 80ac4a4c 802ab214 0 80ac3ad0 3948/4096 ip/2:2
Hwe 80012d73 80ac5a7c 804fee28 0 80ac4ad8 3988/4096 icmp2
Hwe 80065ada 80ac6a74 801b8b0c 0 80ac5ae0 3972/4096 riprx1
Hsi 800487be 80ac7a9c 80117d58 0 80ac6ae8 3976/4096 riptx1
Hwe 80012d73 80ac8a8c 804fee00 0 80ac7af0 3980/4096 udp_thread
Hwe 80012d73 80ac9a7c 804fedd8 0 80ac8af8 3956/4096 tcp_thread
Hwe 80012d73 80acaa9c 804fedb0 0 80ac9b00 3980/4096 fover_ip
Cwe 80011603 80acba84 8031b6ec 0 80acab08 3948/4096 ip/3:3
Hwe 80012d73 80accab4 804fed88 0 80acbb10 3988/4096 icmp3
Hwe 80065ada 80acdaac 801b8acc 0 80accb18 3972/4096 riprx1
Hsi 800487be 80acead4 80117d58 0 80acdb20 3976/4096 riptx1
Hwe 80012d73 80acfac4 804fed60 0 80aceb28 3980/4096 udp_thread
Hwe 80012d73 80ad0ab4 804fed38 0 80acfb30 3956/4096 tcp_thread
Hwe 80006c09 80ad1a88 8007d27c 0 80ad0b38 3896/4096 fover_rx
Hwe 8000c801 80ad2b08 8011c164 0 80ad1b40 4024/4096 fover_tx
Hwe 8000adbe 80ad3b10 8011c170 0 80ad2b48 4024/4096 fover_rep
Hwe 8000cbaf 80ad4afc 8011c178 0 80ad3b50 3988/4096 fover_parse
fw2#
(END)
