09-16-2006 12:10 AM - edited 03-09-2019 04:13 PM
The config about NAT GLOBAL AND STATIC :
global (outside) 1 interface
global (inside) 1 10.1.1.1
nat (outside) 1 access-list acl1 outside 0 0
nat (inside) 1 10.1.1.0 255.255.255.0 0 0
static (inside,outside) 192.168.1.3 10.1.1.3 netmask 255.255.255.255 0 0
It is known that we can config "static" and "ACL" together to permit the traffic from outside into inside. It is work well before I add nat (outside) and global (inside) configurations .
09-16-2006 12:15 AM
ACL1:
access-list acl1 permit any host 192.168.1.1
I found that if the traffic NOT MATCH acl1, the outside host can not connect to 192.168.1.3 although STATIC/ACL has been configured.
And , PIX error message is display:
%PIX-3-305005: No translation group found for protocol src
interface_name:dest_address/dest_port dst
interface_name:source_address/source_port
09-17-2006 10:45 PM
I don't know exactly what you want to do but:
INSIDE --> OUTSIDE
use the nat and global command only:
--> Your network 10.1.0.0/24 will be translated into the IP address of your outside interface when it goes to outside
access-list inside_access_in permit ip 10.1.0.0 255.255.0.0 any
access-group outside_access_in in interface outside
--> the ACL which permits traffic from inside to outside
OUTSIDE-->INSIDE
use the static command:
--> The address 10.1.1.3 in your Network has a "public" address (192.168.1.3), which makes possible the outside to reach it.
access-list outside_access_in permit ip any host 192.168.1.3
--> An ACL which permits traffic from any host in the Outside to your local address 10.1.1.3
With this configuration:
1/ The inside hosts can go outside
2/ The outside hosts can connect to 10.1.1.3
