Timeout sessions
gio9779
Community Member
I have a server connecting to another server on another site. I have created a static NAT for my server, but I have a problem that after about 2 minutes of idle time the connection is lost and I can not communicate with the other server until it opens the connection again.
I think it is the other firewall on the other site that has a PAT and a timeout on the session of about 2 minutes but their administrator claims this is untrue.
Is there anything I can do to avoid this session timeout or to proove that is not my firewall.
many thanks in advance
scoclayton
Level 11
Level 11
Based on your description of the problem, I am inclined to agree that the issue is indeed on his side of the connection. The fact that the connection cannot be re-established *until* the other side re-opens the connection tells me this is not a problem on your side. Even if the connection was closed on your PIX, it would be re-opened when you tried to re-initiate the connection. Sounds like you may need to assist him in troubleshooting his side of the connection. Good luck!
Scott
shannong
Level 9
Level 9
Ask how the remote site is providing NAT? [static, nat 0, nat/global] Is the remote site using a Pix also?
Regardless of xlate timeouts, the connection will be torn down if idle. What kind of OS and application? The best solution would be to use TCP keep-alives to prevent the session from being idle according to the firewall.
