Enable syslogging on the PIX, and check the syslog messages when a session is terminated. You'll probably see a message like:
%PIX-6-302002: Teardown TCP connection id for faddr IP_addr/port gaddr IP_addr/port laddr IP_addr/port (username) duration time bytes num (chars)
where (chars) will be one of (hope this formats OK):
TCP Termination Reasons
| Reason | Description |
| Reset-I | Reset was from the inside. |
| Reset-O | Reset was from the outside. |
| TCP FINs | Normal close down sequence. |
| FIN Timeout | Force termination after 15 seconds |
| | awaiting for last ack |
| SYN Timeout | Force termination after 2 minutes awaiting |
| | three way handshake completion. |
| Xlate Clear | Command line removal |
| Deny | Terminate by application inspection. |
| SYN Control | Back channel initiation from wrong side. |
| Uauth Deny | Deny by URL filter. |
| Unknown | Catch all error. |
The reason will give you an indication of why the session was closed down.
