Traffic Issue(Https, http, ftp)
TBarresi
Community Member
We are having issues going through the ASA 5540(7.11)to the internet. It is very slow. Ports are all configured right. This is a non production network. On our production network we have an FWM and we are having no issue there.
Patrick Laidlaw
Level 9
Level 9
Can you post your config maybe there is something in there. Try looking at your MTU.
Patrick
Here is the asa primary config.
ACCESS TO THIS DEVICE IS STRICLTY PROHIBITED. ALL CONNECTIONS ARE MONITORED AND LOGGED.
xxxxxx# sho conf
: Saved
: Written by enable_15 at 15:03:01.711 EST Mon Mar 27 2006
ASA Version 7.1(1)
hostname xxxxxxxxx
domain-name xxxx.xxx
enable password xxxxxxxx.xxxxxxxxx encrypted
names
interface GigabitEthernet0/0
description vlan_xxx_outside
nameif outside
security-level 0
ip address xxx.xxx.xxx.xxx xxx.xxx.xxx.xxx standby xxx.xxx.xxx.xxx
interface GigabitEthernet0/1
description vlan_xxx_inside
nameif inside
security-level 100
interface GigabitEthernet0/2
description vlan_xxx_dmz
shutdown
nameif dmz
security-level 40
interface GigabitEthernet0/3
description LAN Failover Interface
interface Management0/0
nameif management
security-level 100
management-only
passwd /xxxxx.xxxx.xxxx.xxxx encrypted
banner login ACCESS TO THIS DEVICE IS STRICLTY PROHIBITED. ALL CONNECTIONS ARE MONITORED AND LOGGED.
boot system disk0:/asa711-k8.bin
ftp mode passive
clock timezone EST -5
clock summer-time EDT recurring
dns server-group DefaultDNS
domain-name xxxxx.xxx
access-list acl_outside extended permit icmp any host xxx.xxx.xxx.xxx echo
access-list acl_outside extended permit icmp any host xxx.xxx.xxx.xxx echo-reply
access-list acl_outside extended permit icmp any host xxx.xxx.xxx.xxx source-quench
access-list acl_outside extended permit icmp any host xxx.xxx.xxx.xxx unreachable
access-list acl_outside extended permit icmp any host xxx.xxx.xxx.xxx time-exceeded
pager lines 24
logging enable
logging asdm informational
mtu outside 1500
mtu inside 1500
mtu dmz 1500
mtu management 1500
failover
failover lan unit primary
failover lan interface lanfo GigabitEthernet0/3
failover key *****
failover interface ip lanfo 192.168.200.1 255.255.255.0 standby 192.168.200.2
asdm image disk0:/asdm511.bin
no asdm history enable
arp timeout 14400
global (outside) 3 xxx.xxx.xxx.xxx netmask xxx.xxx.xxx.xxx
global (outside) 1 xxx.xxx.xxx.xxx netmask xxx.xxx.xxx.xxx
global (outside) 5 xxx.xxx.xxx.xxx netmask xxx.xxx.xxx.xxx
nat (inside) 3 xxx.xxx.xxx.xxx xxx.xxx.xxx.xxx
nat (inside) 5 xxx.xxx.xxx.xxx xxx.xxx.xxx.xxx
nat (inside) 1 xxx.xxx.xxx.xxx xxx.xxx.xxx.xxx
access-group acl_outside in interface outside
route outside xxx.xxx.xxx.xxx xxx.xxx.xxx.xxx
route inside xxx.xxx.xxx.xxx xxx.xxx.xxx.xxx
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00
timeout mgcp-pat 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
http server enable
http xxx.xxx.xxx.xxx xxx.xxx.xxx.0 inside
http 192.168.1.0 255.255.255.0 management
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
ssh xxx.xxx.xxx.xxx xxx.xxx.xxx.0 inside
ssh timeout 3
ssh version 2
console timeout 0
dhcpd lease 3600
dhcpd ping_timeout 50
class-map inspection_default
match default-inspection-traffic
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect dns maximum-length 512
service-policy global_policy global
ohliger
Community Member
It looks like that we have the same problem. We are already using the ASA5540 in production environment and also used before the FWSM (no problems). Now if i am trying FTP for example i got only 1/10th of the possible throughput (compared to the download rate in front of ASA) ... The FTP process starts with the same rate, but this is immediately decreased to the slow rate as stated before.
Any hints, our MTU size is default 1500 bytes
