Unconsumed token(s)....??
chrisv
I get the message below when I run SigWizMenu. Is there anything serious with the two "Unconsumed token..." lines?
Thanks in advance,
Chris
-Load File: /usr/nr/etc/SigData.conf
Unconsumed token(s) [DeObfuscate True] passed to parameter "MinHits"
-Load File: /usr/nr/etc/SigUser.conf
-Load File: /usr/nr/etc/SigSettings.conf
marcabal
It looks like 2 signature definitions in the Cisco created SigData.conf file may not have been understood by SigWizMenu.
What Signature Update level are you running? If it is not the latest, then I would suggest upgrading your sensor to the next Signature Update.
If there were a problem in the Cisco created SigData.conf file, then it would have been corrected in the nect Signature Update. SigData.conf is replaced with each new Signature Update on the sensor.
I do have the latest signature (3.1(3)S37) on the IDS.
