Upgrade Packet Downloading Fails
natehausrath
I'm attempting to download the regular 6.0.3 package through the web interface from the Cisco.com site. I had begun this process before, but MARS restarted before it could finish downloading. As a result, the package did not finish. Now, whenever I try to download the package, it tells me:
Attempted to download csmars-6.0.3.3188.zip failed because the file is already being downloaded.
Is there any way I can delete the old package and restart the download? Unfortunately, it does not show up in the web interface so I can't do it that way.
Thanks for any help!
7 Replies 7
Farrukh Haroon
The new java card did the same for me, so I just logged in from another CCO account and downloaded the required file.
I know that this is a pretty absurd suggestion, but it works :)
Farrukh
Unfortunately this did not work for me. Is there a way to see and remove downloaded files via the console or anything?
You could try cycling the MARS services if possible, maybe this could help
Good suggestion, but unfortunately this didn't work either. I'm guessing there isn't an easy way to do this other than going into expert mode, which I haven't had to do before.
There was an easy way! It turns out that by running pnupgrade from the command line and pointing it to an FTP or HTTP server will work. Problem solved!
Nathaniel,
Thanks for following up and posting the solution to your problem. A "5" from NYC.
Best,
Paul
Thanks for posting the solution
