Using NBAR to block IM
danielj
I found an article about using NBAR to block P2P on Cisco Routers, but is it possible to block IM using the same features?
I have a PIX 525 connected to a 2610XM as my headend router.
TIA,
Daniel Jimenez
umedryk
Level 5
Level 5
Find out the port number used in that particular application ( As far as I know, IM is a chat application ), and block that port on PIX.
I'm interested as well.
As far as I know you can block IM in the following ways:
1) block the TCP port it uses, but this is problematic because they can and frequently do use port 80
2) block the login servers for the IM program - difficult to maintain
3) Use some sort of application aware mechanism like NBAR or Packeteer that can distinguish an application regardless of the layer4 port (like looking a layer7)
Can NBAR do this for IM?
