Using vpnclient on RedHat 7.3
werner
in installed the cisco vpnclient for linux (3.5.Rel-k9) on my RedHat 7.3 linux distro and i get the following error messages at boot :
Sep 2 07:50:51 localhost vpnclient: Starting /usr/local/bin/vpnclient:
Sep 2 07:50:51 localhost vpnclient: /lib/modules/2.4.18-5custom/CiscoVPN/cisco_ipsec:
Sep 2 07:50:51 localhost vpnclient: Failed (insmod)
Sep 2 07:50:51 localhost vpnclient: unresolved symbol get_fast_time
Sep 2 07:50:51 localhost vpnclient: Hint: You are trying to load a module without a GPL compatible license
Sep 2 07:50:51 localhost vpnclient: and it has unresolved symbols. Contact the module supplier for
Sep 2 07:50:51 localhost vpnclient: assistance, only they can help you.
Sep 2 07:50:51 localhost rc: Starting vpnclient: failed
Can anybody help me on this .. ?
Werner Ramaekers
dpatkins
I am loading 3.6.1 on a Red Hat 7.3 OS and I am having problems finding the library Kernel modules to do the build. Any ideas on this?
Where did you download the 3.6.1 version from ?
What library kernel modules are you missing ? is it the sources ?
what error trace did you get ?
Werner
Downloaded it from Cisco, but I am having troubles locating the kernel headers.
When it asks you about the kernel headers, what do you put in there?
