very strange
y.haraguchi
Hi. I'm using a PIX515E at my company and users are using vpn client to remote access. Everything is OK, untill days before. One user out and live in a hotel and use the ADSL share in the hotel. He try to use vpn client. After he pass the auth he can't use any resource inside. Use ipconfig it get a IP from the pool, but can't ping anything. If we take this notebook to another ADSL access point (with globle IP), nothing wrong. I asked the engineer in the hotel he said the router is using NAT. I can't change anything in the router, so what should I do? I update to vpn client 4.6 still problem. And the notebook is XP with sp1.
thanks
Another thing is: days before he do can use VPN client to access our inside network in this hotel. Only after a weekend he turn on the PC nothing working. WHYYYYYY......???????
jmia
Level 7
Level 7
Yukio,
Add command: (in config mode) : isakmp nat-traversal - on your pix 515E.
Let me know if this helps.
Jay
