virtual interface
arvindsa
Community Member
Hi Gurus,
I have Cisco pix 515E (HA) firewall on production setup. Initially setup was done for less number of private hosts, so setup is like:
Inside Interface IP is 10.10.8.0/255.255.255.0 .. Here I can use only 255 hosts
My question is Can I add one more private IP block on pix as virtual interface. What is the complete procedure to solve this issue or any other good suggestion without disturbing production pix configuration (as ACL also defined with 255.255.255.0).
jackko
Level 11
Level 11
it's not feasible to configure a secondary ip on pix interface, and virtual interface works with vlan only.
may be you can resolve the issue by modifying the subnet mask.
e.g.
10.10.8.0 255.255.255.0 --> host 10.10.8.1 - 10.10.8.254
10.10.8.0 255.255.254.0 --> host 10.10.8.1 - 10.10.9.254
10.10.8.0 255.255.252.0 --> host 10.10.8.1 - 10.10.11.254
then, you can modify the dhcp scope on the dhcp server for the pc.
arvindsa
Community Member
can u also tell me how do i create a vlan ?
Arvind
it's very straight forward on the pix.
http://www.cisco.com/en/US/products/sw/secursw/ps2120/products_command_reference_chapter09186a00801727a9.html#wp1075586
most of the vlan config will be done on the router or switch in the lan.
