Voice over GRE
tech
Folks,
Is it possible to pass voice traffic over GRE tunnel (Unencrypted) and pass data encypted over the internet between two sites. I think if i try to encrypt voice along with data, the voice quality might be effect.
mchin345
Level 6
Level 6
In my setup, I am moving both voice and data after encryption. What we are doing is using the VAC and QoS. You could consider this solution if you need to protect your voice traffic too. See http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122cgcr/fqos_c/fqcprt7/qcfvoice.htm for more info on QoS for voice.
