VPC Client for Linux and SUSE 9.2 installation problem
lumecir
I try to install VPN Client for Linux ver. 4.6.03.0190 on PC with SUSE 9.2, but I receive this message:
Cisco Systems VPN Client Version 4.6.03 (0190) Linux Installer
Copyright (C) 1998-2005 Cisco Systems, Inc. All Rights Reserved.
By installing this product you agree that you have read the
license.txt file (The VPN Client license) and will comply with
its terms.
Directory where binaries will be installed [/usr/local/bin]
Automatically start the VPN service at boot time [yes]
In order to build the VPN kernel module, you must have the
kernel headers for the version of the kernel you are running.
Directory containing linux kernel source code [/lib/modules/2.6.8-24-default/build]
* Binaries will be installed in "/usr/local/bin".
* Modules will be installed in "/lib/modules/2.6.8-24-default/CiscoVPN".
* The VPN service will be started AUTOMATICALLY at boot time.
* Kernel source from "/lib/modules/2.6.8-24-default/build" will be used to build the module.
Is the above correct [y]
Making module
make -C /lib/modules/2.6.8-24-default/build SUBDIRS=/home/Lucas/Instal/Cisco_VPN_Client/vpnclient-linux-x86_64-4.6.03.0190-k9/vpnclient modules
make[1]: Entering directory `/usr/src/linux-2.6.8-24-obj/i386/default'
make[1]: *** No rule to make target `modules'. Stop.
make[1]: Leaving directory `/usr/src/linux-2.6.8-24-obj/i386/default'
make: *** [default] Error 2
Failed to make module "cisco_ipsec.ko".
I tried to find some advice on Cisco WWW, but I find nothing. Could please someone tell me what is wrong and what to do? Thanks in advanced.
Lukas Mecir
Albit Technologies Network Specialist
lumecir
Oops, I resolved it myself... Source code of kernel was not installed...
Hello...I've run into the exact same problem myself. However, I'm so new at using Suse 9.3 that I can't figure out the solution. Can you provide a little more info on your solution? TIA for any advice/help.
After taking a look at my output from trying to install the vpn client...I found that there are differences:
linux:/home/guest/vpnclient # ./vpn_install
Cisco Systems VPN Client Version 4.6.02 (0030) Linux Installer
Copyright (C) 1998-2004 Cisco Systems, Inc. All Rights Reserved.
its terms.
Directory containing linux kernel source code [/usr/src/linux]
* Modules will be installed in "/lib/modules/2.6.11.4-20a-default/CiscoVPN".
* Kernel source from "/usr/src/linux" will be used to build the module.
Making module
make -C /usr/src/linux SUBDIRS=/home/guest/vpnclient modules
make[1]: gcc: Command not found
make[1]: Entering directory `/usr/src/linux-2.6.11.4-20a'
Makefile:494: .config: No such file or directory
/usr/src/linux-2.6.11.4-20a/scripts/gcc-version.sh: line 11: gcc: command not fo und
/usr/src/linux-2.6.11.4-20a/scripts/gcc-version.sh: line 12: gcc: command not fo und
WARNING: Symbol version dump /usr/src/linux-2.6.11.4-20a/Module.symvers is miss ing; modules will have no modversions.
CC [M] /home/guest/vpnclient/linuxcniapi.o
/bin/sh: gcc: command not found
make[2]: *** [/home/guest/vpnclient/linuxcniapi.o] Error 127
make[1]: *** [_module_/home/guest/vpnclient] Error 2
make[1]: Leaving directory `/usr/src/linux-2.6.11.4-20a'
If anyone has any ideas I would appreciate the input....TIA
Have you tried to install GCC?
Look in yast, software management and search for gcc.
