VPN3000 DHCP issues
jacrawley
When Users connect to this device they are given a dhcp address in a 172 subnet despite the fact that this concentrator is in a 10.x subnet. The DHCP server, a w2k server, is shared between 2 different VPN's and has dhcp pools for both 172.x and 10.x ranges. Is there a way to force them to get ip's in the correct range?
thanks
Joseph
ivillegas
Level 6
Level 6
Make sure DHCP Relay functionality is enabled on the concentrator and that the DHCP server address is mentioned. Refer URL http://www.cisco.com/en/US/products/hw/vpndevc/ps2284/products_configuration_example09186a008014a344.shtml for config example.
under config-sys-servers-dhcp my dhcp server is configured and is currently assigning leases to clients that connect. The issue is that clients connecting to this second vpn need to be assigned a 10.x address and they are not. The dhcp server has lease scopes for this subnet.
thanks
Joseph
