VPN3K and ios with 3des and RSA certs
emleon
Hi all I'm looking for an example to configure VPN3K and ios with 3des and RSA certs
pcomeaux
Here's a good example of the VPN3k to the IOS Router:
http://www.cisco.com/warp/public/471/ALTIGAR.shtml
but it is not using Digital Certificates.
Here's a page on how to form an IPSec tunnel between a Pix and IOS using certificates:
http://www.cisco.com/warp/public/707/lan_to_lan_ipsec_pix_rtr_cert.html
Use this link on how to setup the IOS side.
Here's a link on how to use Digital Certs with the VPN concentrator with VPN clients:
http://www.cisco.com/warp/public/471/installboth.html
If you follow the examples and understand how to make these connections happen, you should be able to use these to create the IpSec tunnel between the concentrator and the router.
peter
