02-17-2005 05:02 AM - edited 03-09-2019 10:22 AM
CLIENT <--- https --- VPN3005 --- http ---> SERVER
version 4.1.7
The HTTP header appears in the browser's display. Looks like the VPN3005 would start interpreting the HTTP header as html code.. Anybody has an idea ?
I found this in the bug tool, but my problem appears with all major browser types.
BugID: CSCef31966
Title: webvpn does not mangle pages correctly
Feature: software-3000
Version: 4.1
Integrated:
Severity: 3
State: A
02-17-2005 04:52 PM
I'd say there's something in the HTML code in your header that the WebVPN mangler isn't interpreting properly.
For starters, I would recommend upgrading to 4.1.7D cause each new release of code has a lot of WEbVPn fixes in it (there's lots of "WebVPN doesn't work with www.somewebsite.com" type bugs that get fixed with each release).
Failing that, we would need to see the original HTML code and what the 3005 mangles it to via the WebVPN session. To do this, here is the process to enable WEBVPN logging. I would suggest that you enable this at the point where the web
page of concern is one click away, and then once the page has completed, then disable
the logging ie: only capture the one page and not other pages that you might
have to go to prior to the page of concern.
To do this, you need to go into the CLI via the console port. At the main
menu, follow this path to the WEBVPN logging options. The WEBVPN username is
needed, Capture all HTTP traffic, then once here, make sure that you are
just one click away from the page of interest, enable the logging, then wait
for the page to complete before disabling logging and then follow the same
process for the other two web pages. At this stage, it would be worthwhile
to also capture the WEBVPN events for completeness.
>From the main menu....
3, 2, 5, 1 {WEBVPN Username}, 2 {all http traffic}, 3
Here's a complete transaction..
1) Configuration
2) Administration
3) Monitoring
4) Save changes to Config file
5) Help Information
6) Exit
VPN3060_UK: Main -> 3
1) Routing Table
2) Event Log
3) System Status
4) Sessions
5) General Statistics
6) Dynamic Filters
7) Back
VPN3060_UK: Monitor -> 2
1) Configure Log viewing parameters
2) View Event Log
3) Save Log
4) Clear Log
5) Configure WebVPN Logging
6) Back
VPN3060_UK: Log -> 5
WebVPN Logging: OFF
User: "NULL"
Path: "NULL"
1) Set Username
2) Set Path
3) Enable/Disable WebVPN Logging
4) Back
VPN3060_UK: WebVPN Logging -> 1
Enter the name of the user to capture.
>> Username to Log
VPN3060_UK: WebVPN Logging -> vpnuser <---- WEBVPN UserID
WebVPN Logging: OFF
User: "vpnuser"
Path: "NULL"
1) Set Username
2) Set Path
4) Back
VPN3060_UK: WebVPN Logging -> 2
Enter the path to capture.
Format:
/http[s]/
Use "/http" to capture everything.
Use "/http/0/
Use "/https/0/
>> Path Prefix to Log
VPN3060_UK: WebVPN Logging -> /http <---- all http traffic
WebVPN Logging: OFF
User: "vpnuser"
Path: "/http"
1) Set Username
2) Set Path
4) Back
VPN3060_UK: WebVPN Logging -> 3
WARNING:-- Enabling this feature will impact performance.
1) Enable WebVPN Logging
2) Disable WebVPN Logging
VPN3060_UK: WebVPN Logging -> [ 2 ] 1 <---- Enable
WebVPN Logging: ON
User: "vpnuser"
Path: "/http"
Once you have gone through one capture cycle, you will then need to send us the
original.txt and mangled.txt files from the concentrator.
I wouldn't recommend posting them up here on a public forum. I'd suggest at this point you open a TAC case and post them up there along with the screen-shot you provided, they can then investigate what's going on and get it fixed if necessary.
