01-09-2004 10:57 AM - edited 03-09-2019 06:05 AM
Hello all,
I got a problem with a PIX515E, Cisco PIX Firewall Version 6.3(1)
Cisco PIX Device Manager Version 3.0(1):
there are 3 networks involved: outside, DMZ, net3
- security levels: outside=0, DMZ=60, net3=80
- from both outside and DMZ, I need to go to a smtp-server that is reachable via the interface on net3
- from outside it is ok, from DMZ it is not (so the route to the smtp server is ok)
- the access-lists are the same (except for interface and source IPs of course)
- no translations need to be done, configured the same
- this is what I see in the logs when I try to connect from DMZ to the smtp-server:
%PIX-6-305009: Built static translation from net3:IP3 to outside:IP3
instead of the expected "%PIX-6-305009: Built static translation from net3:IP3 to DMZ:IP3
and:
%PIX-6-302013: Built inbound TCP connection 22996564 for DMZ:IPDMZ/2326 (IPDMZ/2326) to net3:IP3/25 (IP3/25)
%PIX-4-106023: Deny tcp src net3:IP3/25 dst DMZ:IPDMZ/2326 by access-group "net3-in"
Captured traffic:
IPDMZ.1871 > IP3.25: S 2792848283:2792848283(0) win 65535 <mss 1380,nop,nop,sackOK>
IP3.25 > IPDMZ.1871: S 1669425112:1669425112(0) ack 2792848284 win 65535 <mss 1460,nop,nop,sackOK>
IPDMZ.1871 > IP3.25: R 2792848284:2792848284(0) ack 1669425113 win 65535 <mss 1460,nop,nop,sackOK>
- arp entries are ok; a clear xlate doesn't solve the problem
What is strange also, is that I had the same config in but with a different IP address for the smtp-server, which worked. The only difference now is that the IP of the smtp-server has changed...
Anyone seen this before ? Any tips ?
Thanks for any help !
01-09-2004 07:06 PM
This is what the problem is
We need to see the configs...
Nadeem
01-12-2004 04:35 AM
this is some more info on the config; due to customer confidentiality, I needed to rework it a bit, and state only the lines related to this problem. This extract should be enough though, I think, as there are no deny-statements anywhere. So, I ld expect the firewall to accept the request to connect to the smtp-server, and following that, allow all return-traffic for this same connection back in, as it is stateful ?!
There is no rule that permits setting up SMTP-traffiek from net3 towards the networks DMZ or outside, but this is intended: we only want people to set up connections towards the SMTP-server, and not in the other direction.
(one can see from the captured traffic that no new connection is set up anyway.)
interface ethernet0 100full
interface ethernet2 100full
interface ethernet3 100full
nameif ethernet0 outside security0
nameif ethernet2 net3 security80
nameif ethernet3 DMZ security60
fixup protocol ftp 21
no fixup protocol h323 h225 1720
no fixup protocol h323 ras 1718-1719
fixup protocol http 80
no fixup protocol ils 389
no fixup protocol rsh 514
no fixup protocol rtsp 554
no fixup protocol sip 5060
no fixup protocol sip udp 5060
no fixup protocol skinny 2000
fixup protocol smtp 25
no fixup protocol sqlnet 1521
access-list outside-in permit tcp object-group outside-hosts host smtp-server eq smtp
access-list net3-in : there is no deny-statement in this list, only permits
access-list DMZ-in permit tcp object-group DMZ-hosts host smtp-server eq smtp
mtu outside 1500
mtu net3 1500
mtu DMZ 1500
nat (inside) 0 0.0.0.0 0.0.0.0 0 0
nat (net3) 0 0.0.0.0 0.0.0.0 0 0
nat (DMZ) 0 0.0.0.0 0.0.0.0 0 0
static (net3,outside) 192.168.3.0 192.168.3.0 netmask 255.255.255.0 0 0
static (net3,DMZ) 192.168.3.0 192.168.3.0 netmask 255.255.255.0 0 0
access-group outside-in in interface outside
access-group net3-in in interface net3
access-group DMZ-in in interface DMZ
route net3 192.168.3.0 255.255.255.0 gw-to-192.168.3.0
timeout xlate 1:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
thanks,
Bart
