cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
Respuestas
ubr10K Bonding with Edge qam
Pascal Faucher
I try to make bonding with ubr10K (mc20x20) and edge qam
(node1) (6/1/4) 8DS from edge qam or
(node 2) 4 DS from mc20x20 and 4 DS from EdgeQam
My config (for 8DS from edge Qam)
Do you see something wrong in my config ?
Edge qam ip 10.80.0.2 ( harmonic NSG 9000)
ubr10k (ubr can ping the edge qam)
interface GigabitEthernet1/0/0
ip address 10.80.0.1 255.255.255.0
negotiation auto
interface Cable6/1/4
downstream Modular-Cable 1/0/0 rf-channel 0-7 upstream 0-3
cable mtc-mode
no cable packet-cache
cable max-hosts 5
cable bundle 1
cable upstream max-ports 4
cable upstream bonding-group 119
upstream 0
upstream 1
upstream 2
upstream 3
attributes A0000000
cable upstream 0 connector 16
cable upstream 0 frequency 18800000
cable upstream 0 channel-width 3200000 3200000
cable upstream 0 description LAB-TEST-U0-18.8
cable upstream 0 docsis-mode tdma-atdma
cable upstream 0 minislot-size 2
cable upstream 0 range-backoff 3 6
cable upstream 0 modulation-profile 121
no cable upstream 0 shutdown
cable upstream 1 connector 17
cable upstream 1 frequency 29200000
cable upstream 1 channel-width 3200000 3200000
cable upstream 1 description LAB-TEST-U1
cable upstream 1 docsis-mode tdma-atdma
cable upstream 1 minislot-size 2
cable upstream 1 range-backoff 3 6
cable upstream 1 modulation-profile 121
no cable upstream 1 shutdown
cable upstream 2 connector 18
cable upstream 2 frequency 32400000
cable upstream 2 channel-width 3200000 3200000
cable upstream 2 description LAB-TEST-U2
cable upstream 2 docsis-mode tdma-atdma
cable upstream 2 minislot-size 2
cable upstream 2 range-backoff 3 6
cable upstream 2 modulation-profile 121
no cable upstream 2 shutdown
cable upstream 3 connector 19
cable upstream 3 frequency 35600000
cable upstream 3 channel-width 3200000 3200000
cable upstream 3 description LAB-TEST-U3
cable upstream 3 docsis-mode tdma-atdma
cable upstream 3 minislot-size 2
cable upstream 3 range-backoff 3 6
cable upstream 3 modulation-profile 121
no cable upstream 3 shutdown
interface Wideband-Cable1/0/0:0
cable bundle 1
cable rf-channel 0 bandwidth-percent 20
cable rf-channel 1 bandwidth-percent 20
cable rf-channel 2 bandwidth-percent 20
cable rf-channel 3 bandwidth-percent 20
cable rf-channel 4 bandwidth-percent 20
cable rf-channel 5 bandwidth-percent 20
cable rf-channel 6 bandwidth-percent 20
cable rf-channel 7 bandwidth-percent 20
interface Modular-Cable1/0/0:0
cable bundle 1
cable rf-bandwidth-percent 20
cable fiber-node 19
upstream Cable 6/1 connector 16-19
controller Modular-Cable 1/0/0
modular-host subslot 6/1
rf-channel 0 frequency 603000000 annex B modulation 256qam interleave 32
rf-channel 0 ip-address 10.80.0.2 mac-address 0090.f002.9dbe depi-remote-id 11000
rf-channel 1 cable downstream channel-id 194
rf-channel 1 frequency 60900000 annex B modulation 256qam interleave 32
rf-channel 1 ip-address 10.80.0.2 mac-address 0090.f002.9dbe depi-remote-id 11001
rf-channel 2 cable downstream channel-id 195
rf-channel 2 frequency 61500000 annex B modulation 256qam interleave 32
rf-channel 2 ip-address 10.80.0.2 mac-address 0090.f002.9dbe depi-remote-id 11002
rf-channel 3 cable downstream channel-id 196
rf-channel 3 frequency 62100000 annex B modulation 256qam interleave 32
rf-channel 3 ip-address 10.80.0.2 mac-address 0090.f002.9dbe depi-remote-id 11003
rf-channel 4 cable downstream channel-id 197
rf-channel 4 frequency 62700000 annex B modulation 256qam interleave 32
rf-channel 4 ip-address 10.80.0.2 mac-address 0090.f002.9dbe depi-remote-id 11004
rf-channel 5 cable downstream channel-id 198
rf-channel 5 frequency 63300000 annex B modulation 256qam interleave 32
rf-channel 5 ip-address 10.80.0.2 mac-address 0090.f002.9dbe depi-remote-id 11005
rf-channel 6 cable downstream channel-id 199
rf-channel 6 frequency 63900000 annex B modulation 256qam interleave 32
rf-channel 6 ip-address 10.80.0.2 mac-address 0090.f002.9dbe depi-remote-id 11006
rf-channel 7 cable downstream channel-id 200
rf-channel 7 frequency 64500000 annex B modulation 256qam interleave 32
rf-channel 7 ip-address 10.80.0.2 mac-address 0090.f002.9dbe depi-remote-id 11007
5 RESPUESTAS 5
Manuel Rodriguez
Hi Pascal,
The only observation I have is that you only configured one Modular-Cable interface (1/0/0:0) but you included the 8 channels from the SPA in the MD as primary channels. You should configure the other 7 modular-cable interfaces if you expect to use those as primary channels.
Regarding bonding group, it looks fine. I see the 8 channels added in the wideband-cable interface and correct fiber-node configuration. You may want to double check using "show cable mac-domain cable 6/1/4 rcc". IF RCCs are populated, you should normally be OK to do wideband.
Regards.
Hi Manuel
Thanks for the answer.
can I do
4 DS from mc20x20 ( Primary DS)
cable modem do not wideband with modular cable.
note.  I do not use a DTI server, the traffic from SPA is just non-primary (just for wideband).
controller Integrated-Cable 6/1/4
rf-channel 0 cable downstream channel-id 89
rf-channel 0 frequency 579000000 annex B modulation 256qam interleave 32
rf-channel 0 rf-power 52.0
no rf-channel 0 rf-shutdown
rf-channel 1 cable downstream channel-id 90
rf-channel 1 frequency 585000000 annex B modulation 256qam interleave 32
rf-channel 1 rf-power 52.0
no rf-channel 1 rf-shutdown
rf-channel 2 cable downstream channel-id 91
rf-channel 2 frequency 591000000 annex B modulation 256qam interleave 32
rf-channel 2 rf-power 52.0
no rf-channel 2 rf-shutdown
rf-channel 3 cable downstream channel-id 92
rf-channel 3 frequency 597000000 annex B modulation 256qam interleave 32
rf-channel 3 rf-power 52.0
no rf-channel 3 rf-shutdown
rf-channel 0 cable downstream channel-id 1
downstream Modular-Cable 1/0/0 rf-channel 0-3 upstream 0-3
downstream Integrated-Cable 6/1/4 rf-channel 0-3 upstream 0-3
cable mtc-mode
cable max-hosts 5
cable bundle 1
upstream 0
upstream 1
upstream 2
upstream 3
attributes A0000000
cable bundle 1
interface Modular-Cable1/0/0:1
cable bundle 1
interface Modular-Cable1/0/0:2
cable bundle 1
interface Modular-Cable1/0/0:3
cable bundle 1
cable bundle 1
interface Wideband-Cable6/1/4:0
cable bundle 1
cable rf-channel 0 bandwidth-percent 46 remaining ratio 100
cable rf-channel 1 bandwidth-percent 46 remaining ratio 100
cable rf-channel 2 bandwidth-percent 46 remaining ratio 100
cable rf-channel 3 bandwidth-percent 46 remaining ratio 100
cable fiber-node 19
sh cable mac-domain cable 6/1/4 rcc
RCC-ID RCP RCs MD-DS-SG CMs WB/RCC-TMPL
38 00 00 00 00 00 4 0 0 WB (Wi1/0/0:0) <---  0 modem
42 00 00 00 00 00 4 0 2 WB (Wi6/1/4:0)
sh cab mac cab 6/1/4 downstream-service-group
Cable MD-DS-SG RF
IF Id Resource Chan Primary Chan
C6/1/4 1 1/0/0 00-03 0 1 2 3
6/1/4 00-03 0 1 2 3
I/F MAC DSxUS Primary
State WB
C6/1/4/UB w-online 4x4 Wi6/1/4:0    should be  8x4 ( 4DS from 6/1/4 and 4 DS from Edge QAm)
thnaks for you help
Hi Pascal,
If the channels from SPA are not used as primary, there is no need to add them under the cable interface (" downstream Modular-Cable 1/0/0 rf-channel 0-3 upstream 0-3") and no need to configure the modular-cable interfaces. Those configurations are only for primary channel functionality.
With this configuration however, you will not be able to do 8 channel DS bonding. You only have 4-channel bonding groups (RCCs). To do 8-channel DS bonding, you need an 8-channel bonding group (meaning, you need an 8-channel wideband interface). I'm afraid you cannot add channels from SPA to wideband interface hosted by 20x20 LC (or any LC) nor vice-versa. This is not supported. You will need to add channels from the same LC or SPA to the corresponding wideband interface. You may use channels from different controllers, but always from the same card.
Regards.
Manuel,
ok I understand  so I can't do  4DS from mc20x20 and 4DS from Edge Qam (total 8x4)
What I can do is
 8 DS from 20x20
or
 8 DS from EQ
The issue is
I want to save  mac domain on my mc20x20 when I do 8 DS from 20x20  I need two mac domain to do this  ex: (6/1/3 and 6/1/4).
interface Cable6/1/4, remain unconfigured, I config only: controller Integrated-Cable 6/1/4
and add it to the fiber node and the windeband int.
cable fiber-node 19
downstream Integrated-Cable 6/1/3 rf-channel 0-3
upstream Cable 6/1/3 connector 12-15
interface Wideband-Cable6/1/3:0
 description wideband 8ds
 cable bundle 1
 cable rf-channel controller 4 channel 0 bandwidth-percent 1 remaining ratio 100
 cable rf-channel controller 4 channel 1 bandwidth-percent 1 remaining ratio 100
 cable rf-channel controller 4 channel 2 bandwidth-percent 1 remaining ratio 100
 cable rf-channel controller 4 channel 3 bandwidth-percent 1 remaining ratio 100
this way I have a 8x4 on the mc20x20.
So I correct my config to do 8DS from EdgeQam and the cable modem still want to come online.
rf-channel 4 frequency 627000000 annex B modulation 256qam interleave 32
cable bundle 1
cable bundle 1
cable bundle 1
cable bundle 1
cable bundle 1
interface Modular-Cable1/0/0:4
cable bundle 1
interface Modular-Cable1/0/0:5
cable bundle 1
interface Modular-Cable1/0/0:6
cable bundle 1
interface Modular-Cable1/0/0:7
cable bundle 1
cable mtc-mode
cable max-hosts 5
cable bundle 1
upstream 0
upstream 1
upstream 2
upstream 3
attributes 80000000
cable fiber-node 19
thanks for your help,
realy appreciate.
38 00 00 00 00 00 8 0 0 WB (Wi1/0/0:0)
sh cable mac-domain cable 6/1/4 downstream-service-group
Cable MD-DS-SG RF
C6/1/4 3 1/0/0 00-07 0 1 2 3 4 5 6 7
So, are you trying to bring modems online in 6/1/4? As I said before, the command " downstream Modular-Cable 1/0/0 rf-channel 0-7 upstream 0-3" and the configuration for interfaces "Modular-Cable1/0/0:X" is to configure primary channel capability on those channels. If you are not using a DTI, I guess you will not be able to use the modular channels as primary. In your configuration the only channels configured as primary for 6/1/4 are the modular ones.
Given the above, which channels are you planning to use as primary for 6/1/4 mac domain?
From a bonding group perspective, the configuration is OK. But is not clear about the primary channels to use. Also, if the primary channels is not part of the bonding group (in case you use primaries from 20x20), you need to consider that the modem must be able to lock on 1 + 8 channels since the modem needs to lock on the primary + all channels in the bonding group. If the modem is not able to bond on more than 8 channels, this may not work.
Regards.
