Bookmark
Subscribe
1549
DUO hardware token usage with third party sites
Tiago_Oliveira
Is it possible to use Duo Hardware token as 2FA with third party websites such as Google, Facebook, etc?
I’m looking for a solution of using hardware tokens to replace Duo Mobile.
Tks in advance
Just to be clear , Duo D-100 Tokens cannot be used to integrate with third party websites such as Google, Facebook, in a similar method (TOTP) as Duo Mobile, is that correct?
Correct.
Do you have any guidance of what we should do in a custom web application to support D-100 hardware tokens as 2FA?
If your web application is integrated into your edition of Duo, you can use D-100 tokens as an authn method. Please see our WebSDK and Auth API documentation.
DuoPablo
Hi @Tiago_Oliveira ,
Duo D-100 hardware tokens cannot be used with other MFA providers, and Duo does not provide the token seeds.
Can I obtain the token seed file to use my Duo D-100 hardware token with other MFA providers?
D-100 tokens also use HOTP while most 3rd parties rely on TOTP for their passcodes. For your use case, any TOTP-supported hardware token should suffice if you are looking to replace Duo Mobile as a 3rd party TOTP authenticator.
Hope this helps!
Hi Pablo
Tks for your response.
tks in advance
Correct.
