Duo Network Gateway: Backup Portion
ckeyy
Hi everyone, does Duo network gateway backup all the settings configured? or selected settings only?
DuoKristina
You should find it includes all settings sufficient to restore the config to a different DNG and wind up with the same config on both.
Duo, not DUO.
