Sailpoint IIQ Duo Standard edition Vs Duo Federal edition
lohith.IN
For testing purpose I have integrated Duo standard edition in dev and MFA authentication is working as it should be I am able to login in Sailpoint dashboard with Duo AuthAPI credentials
“********.duosecurity.com/auth/v2/preauth”.
But for client’s Federal edition when I started to integrate Duo AuthAPI credentials “api-*********.duofederal.com/auth/v2/preauth” I’m getting an exception in pre-auth step as
“unexpected url: https:// api-********.duofederal.com/auth/v2/preauth”
My Question
  1. Is it because Federal edition " .duofederal.com/auth/v2/preauth" doesn’t have the particular endpoint so we are not getting any response or getting exception as above
It would be helpful if any Duo team member gave clarity on this.
Thanks in Advance!!!
DuoKristina
Hi @lohith.IN ,
Responded to your post with the same question here: Error-unexpected url: https:// api-***********.duofederal.com/auth/v2/preauth
Please contact Sailpoint to report this.
Duo, not DUO.
