FDM manged firepower copy config
sheypard
What is the easiest/best way to copy the config from an FDM managed Firepower 1120 to another one exact same model?
I think you can not do that
backup is only work for same device
MHM
Ruben Cocheno
@sheypard
I got this from my notes, it's a script to restore of FDM with existing backup as well. The script is attached here in this document and not not written by me but someone from Cisco that i don't recall (sorry).
1) Preparation:
Step 1: Download the script on PC
Step 2: Make sure python3 is installed on PC and have reachability to FDM on 443
Step 3: Make sure proper permission is given to script to execute (This applies specifically if you're executing script from linux machine)
2) Take Backup of FDM
Flamingo$ python3 fdm-backup.py
# FDM BACKUP AND RESTORE PROGRAM #
Enter the device IP address: 10.106.59.241
Enter the username of the FTD: admin
Enter the password of the FTD:
Auth-Status code is 200
Successfully Authenticated
1. Initiate Backup
2. Restore Backup
Enter your choice (integer value) : 1
Backup Job ID : 7dd983ce-c215-11ea-92a4-cfd908aa67d4
Backup Running...........
Backup Task Succeded
3) Restore Backup on FDM
Enter the device IP address: 10.197.236.209
1. Initiate Backup
2. Restore Backup
Enter your choice (integer value) : 2
# Start Date Archive Name File Size (MB)
1 2020-07-09 18:31:31Z 20200709183131.NGFW_backup.Backup 160.778752
2 2020-07-09 17:12:19Z 20200709171219.NGFW_backup.Backup 160.906752
Select a backup to restore : 2
Are you sure ? (yes,no) : yes
Backup job Initiated with ID 42f5fb70-c215-11ea-af10-4939e9e2e7fa
Please wait until the restore is completed
Tag me to follow up.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
Sorry I can't see the script attached?
