Antenna of CIVS-IPC-2500W
chaijoo_lau
I have a customer going to install CIVS-IPC-2500W at outdooor.
I have read through the datasheet of CIVS-IPC-2500W but can not find any information about suitability of antenna for ourdoor deployment.
My question will be does antenna come with CIVS-IPC-2500W suitable for outdoor deployment?
Do I need new antenna in oder to deploy the camera at outdoor?
Please advice. Thanks.
htarra
Level 4
Level 4
According to the this URL the Cisco 2500 Series Video Surveillance IP Camera comes with 2 antenna's (wireless model only).
http://www.cisco.com/en/US/prod/collateral/vpndevc/ps6918/ps9692/ps7307/data_sheet_c78-455613.html
Hi htarra,
tks for ur respond. I'm aware with the information you mention.
My question is does the antenna come with the camera suitable for outdoor deployment?
You can use the Vieolarm Outdoor enclosure that is certified from Cisco for outdoor environment. Both wired & wireless models are available. The ourdoor unit comes with antennas for Outdoor use.
