CPAM Client Won't connect
wazaberry
I am faced with a strange issue with the client desktop for CPAM. I have CPAM setup and I can ping it from my PC. I installed Java JRE 1.6 and it is working correctly. Whenever I launch CPAM client and enter the server IP and credentials I get an error message: "connection refused: connect" as attached. I tested it from another PC and I get the same result.
Any ideas?
Walid
ncehreli
Hello Walid,
This error is generated when CPAM service is not running on the server. Login CPAM Web GUI as cpamadmin and if the service is stopped, start it using Commands -> Start Server
Best Regards
Necati Cehreli
It's working now. Thanks
Hey guys!
I have the same issue, only that I can not enter to the GUI web of the server. Do you have a command for the Linux CLI to do that??
