Help with Cisco 7070 camera sending video
holleran
I have a few 7070 cameras and need to send the video to someone that does not have the software nor do they want to install it. Is there a way to send a clip that the person can zoom & pan around?
jsah
You can download the camera clip from the VSOM application or from SASD, if you are using this Cisco surveillance application. Without software its not possible to get the recorded clips from camera.
The recording template(s) need to apply on the camera(s) in order to record as per your requirements.
The PAN, Tilt and Zoom is the feature of the camera, it can't done on the recordings clips. If you have the PTZ actions while taking the recording clips then it will visible in recorded clips.
StephanMC
VLC Player will allow them to view the recorded footage. However PTZ is not a Feature available with that camera since its a Fisheye type lens.
