Problem when using windows 7 with VSOM 6.3.0
Yhya Akef
Hi ,
I am facing a problem with VSOM 6.3.0 .
It is not working with Windows 7 .
Any idea ?
David Aicher
Windows 7 client support was added in 6.3.1
6.3.0 may or may not work as it was not tested and is not officially supported with VSOM.
Dave Aicher
Is there any patch to be installed to solve this problem ?
There are no patches that will make 6.3.0 supported with windows 7 client.  The support is in version 6.3.1 and later.  You would need to upgrade the server to the new version.
Check out the following scripts to make the upgrade easier
version 6.3.2
https://supportforums.cisco.com/docs/DOC-17123
version 6.3.1
https://supportforums.cisco.com/docs/DOC-14917
Dave Aicher
Should also add that unless I'm mistaken, or things have changed, only 64bit Windows 7 is supported.  I don't believe 32bit is.
Scott Olsen Solutions Specialist Bulletproof Solutions Inc. Web: www.bulletproofsi.com
