Problemi witch ACL control-plane
rcernigoi
Community Member
Good morning everyone
I need to apply an access list on the outside interface to allow reaching the servers in the DMZ and an access list with the control-plane suffix to mitigate some brute force attacks on the VPN. How can I do? It seems to me that 2 access lists cannot be applied on the same interface...
Thanks everyone for the help
7 Replies 7
Can you more elaborate.
Of course, sorry if I wasn't clear enough:
on the outside I have an access list that allows me to reach a web server that is in dmz
access-list ACL-OUTSIDE extended permit tcp any object obj-SMTP-SERVER object-group obj-SMTP-SERVER-TCP
and applied with
access-group ACL-OUTSIDE in interface outside
at this point I should create an access list like this:
access-list ACL-DENY extended deny ip host xxx.xxx.xxx.xxx any
and apply it to the outside with:
access-group ACL-DENY in interface outside control-plane
If I do this, the ACL-DENY doesn't work for me and from what I saw on the documents found by uncle Google :-), it seems that it is not possible to apply two acl on the same interface. How can I solve it?
Thank you
Hello @rcernigoi,
Merge the deny rule into the existing ACL (ACL-OUTSIDE) as an additional rule at the end:
access-list ACL-OUTSIDE extended deny ip host xxx.xxx.xxx.xxx any
Apply updated ACL to outside Interface:
Best regards
Thanks for the reply but it doesn't work that way. The second ACL is for traffic that stops at the firewall (like a VPN), while the first is for traffic that passes through it. I had already tried as you say but the "jammer" keeps trying to force the VPN
Permit any any
Add this to ACL control-plane and check.
Unfortunately it doesn't work. The problem is that even with the "deny" ACL, no one is blocked, not even the IP specified in the ACL
are this issue solved ?
