Single host mode authentication issue
Jun123123
Frequent Visitor
Frequent Visitor
Currently, the SW is a LAN LITE model and only supports single host mode
Using single-host mode,
If it is connected as shown below
  SW -> (single-host mode setting, mab, dot1x authentication setting)
IP Phone -> (mab authentication, specific vlan assignment)
User PC -> (dot1x authentication, VLAN assignment according to user ID / PW)
As a result,
Using single-host mode, I wonder if both the phone and the user's PC can be authenticated.
Francesco Molino
With single host mode, nope you won't have both devices authenticated and authorized.
I don't have any switch close to me with the same ios version. Can you add check if you can use multiple domain? With this you'll be able to get 1 authentication in the voice domain and 1 for data domain.
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Jun123123
Frequent Visitor
Frequent Visitor
The current lan lite model is WS-C2960X-24TS-LL. The authentication methods are single-host, multidomain, and multi-host.
 It is the second site to build using WS-C2960X-24TS-LL model.
 The site that we built the first time used the multi-auth authentication method using the Lan base-based model to authenticate the phone and the user's PC.
 First, the lan base model of the site that we built has been tested with multi-host authentication method, and the authentication process with the desired condition could not be performed.
  So I chose Multi-auth, and the lan lite device of the second building site did not support multi-auth, so I chose single-host.
 When connecting to a single host, the IP phone receives mab authentication processing and allocates a specific vlan band, and the IP phone can not handle the dot1x authentication processing sent from the SW
 I wonder if the authentication process is done by bypassing to the user pc side.
Not sure i understand what you want to achieve. In single host mode, only 1 authentication is allowed per port.
Francesco
