12-10-2010 08:04 AM
Hi!
We have some Sony SNC-DS60 and DS10 and they are supposed to be dual streaming capable. They are but Cisco VMS doesn't see the secondary stream. Is someone here was able to dual stream from those cameras?
Solved! Go to Solution.
01-06-2011 06:12 AM
Hello Isael
Go to http://
Under Configuration -> Manage Drivers
Click on dp_sony
You will see the documentation about sony camera driver there.
Best Regards
Necati Cehreli
01-04-2011 01:26 PM
Hello Isael
Support for dual streaming for Sony cameras is documented under driver pages of VSMC(dp_sony). There you can see that concurrent streaming for MJPEG/H264 is not supported for some cameras.
Best Regards
Necati Cehreli
01-06-2011 05:55 AM
Thanks! Can you pinpoint me the guide where it is ?
01-06-2011 06:12 AM
Hello Isael
Go to http://
Click on dp_sony
Best Regards
Necati Cehreli
01-06-2011 06:23 AM
Thank you!
