Unable connect to ASA with using https and ADSM
chaiyos_ch
Community Member
I'm trying access to ASA5510 with mozilla browser via https://192.168.1.1/ but couldn't connect show message "An error occurred during a connection to 192.168.1.1. Cannot communicate securely with peer: no common encryption algorithm(s). (Error code: ssl_error_no_cypher_overlap)".
Another method I already have installed the ADSM launcher had tried access to such device and still popup message "Unable to launch Device Manager 192.168.1.1".
Please suggest for method to fix this issues.
Result of the command: "sh run http"
http server enable
http 192.168.1.0 255.255.255.0 INSIDE
Result of the command: "sh run all ssl"
ssl server-version any
ssl client-version any
ssl encryption des-sha1
Result of the command: "sh ver"
Cisco Adaptive Security Appliance Software Version 8.2(5)
Compiled on Fri 20-May-11 16:00 by builders
System image file is "disk0:/asa825-k8.bin"
Config file at boot was "startup-config"
Hardware:   ASA5510, 1024 MB RAM, CPU Pentium 4 Celeron 1600 MHz
Internal ATA Compact Flash, 256MB
BIOS Flash Firmware Hub @ 0xffe00000, 1024KB
Licensed features for this platform:
Maximum Physical Interfaces    : Unlimited
Maximum VLANs                  : 50
Inside Hosts                   : Unlimited
Failover                       : Disabled
VPN-DES                        : Enabled
VPN-3DES-AES                   : Disabled
Security Contexts              : 0
GTP/GPRS                       : Disabled
SSL VPN Peers                  : 2
Total VPN Peers                : 250
Shared License                 : Disabled
AnyConnect for Mobile          : Disabled
AnyConnect for Cisco VPN Phone : Disabled
AnyConnect Essentials          : Disabled
Advanced Endpoint Assessment   : Disabled
UC Phone Proxy Sessions        : 2
Total UC Proxy Sessions        : 2
Botnet Traffic Filter          : Disabled
This platform has a Base license.
chitswemyint
Community Member
I think may be browser problem.try to clear all of mozila (%appdata%) delete mozila folder.
If not, try to other browsers or uninstall firefox and download latest version
chitswemyint,
I have tried as you suggested but couldn't connect to the device.
Chaiyos
