VSM 7 NTP Problem
haris_qazi
Dear All,
I am having problem with Synchronizing NTP with VSOM / VSMS 7. They are co-located, and I have configured NTP both on Core Switch and a Server and pointing the VSMS to those IP, but still I am receiving error regarding the time difference.
Thanks.
kcapoor
Hi Haris,
For co-located server the NTP server is added in management console under system setup-> date and time. make sure you have enter the correct IP here for your NTP server running on switch. can you post your NTP setting on switch for me to have a look if this is correct.
Karan Capoor
PDI-ET Team
