trusted endpoint using guid
Vishal6
Level 6
Level 6
Hi All,
Needs to configure trusted endpoint on windows/mac os user machine using guid. Can anyone know how to do it or share any relevant document
DuoKristina
Your use case is that you have no endpoint management systems from which to source machine info for Duo trusted device verification?
https://duo.com/docs/trusted-endpoints-generic-duo-desktop This integration has you collect your machine identifiers and upload them to Duo via CSV import or API.
https://duo.com/docs/trusted-endpoints-manual#manual-with-duo-desktop is similar, and also requires you to collect identifiers and upload or import them into Duo.
Duo, not DUO.
