04-02-2012 11:18 AM - edited 03-10-2019 06:57 PM
I'm sure something is missing, but I've given it a stab and cant figure it out. Scenario: I am configuring a switch to be sent to a site. I have my cookie cutter config on it and its not connected to the network. When I login via ssh cable between laptop and switch - in it takes a really long time before I can get to privileged EXEC mode. I'm sure it is because the request to login can not communicate with the tacacs server. So I ask given the below config. What can I change to speed up the login for a device that can not communicate with tacacs?
aaa new-model
aaa authentication login default group tacacs+ local
aaa authentication enable default group tacacs+ enable
aaa authorization config-commands
aaa authorization exec default group tacacs+ if-authenticated
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 15 default start-stop group tacacs+
aaa session-id common
Thanks!
04-02-2012 11:41 AM
I suggest reducing "tacacs-server timeout" and "tacacs-server retransmits".
It takes a long time because the IOS will retry and wait before declaring tacacs server dead. Reducing those timers, will reduce wait time.
Nicolas
04-02-2012 12:45 PM
That didnt work Nicholas. I think the "tacacs-server retransmit" was depricated in 12.2 its not an option. I have tried the following and still nogo.
tacacs-server host x.x.x.x single-connection timeout 3
tacacs-server timeout 3
I timed it and it takes 10-30 seconds after I login before I get password prompt
when i put the password in it takes 10 seconds and puts me in user EXEC mode
I type enable and it takes 1 minute before I get a login prompt.
I thought since this was a new switch with time not configured that was the problem, so I configured it and still nogo. This is not a big deal it just bothers me not having an answer. Thanks for your help.
04-02-2012 02:02 PM
You should try the "deadtime" command, by default = 0.
aaa group server tacacs ACS
server 10.10.10.10
deadtime 1
Please rate if it helps. Kind regards
07-09-2018 07:29 AM
Since the device is not yet in the network, it's obvious that it wont reach tacacs servers specified(if specified, i don't see commands tacacs-server host x.x.x.x that specifies the servers) , the device will then hang till the it reaches tacacs timeout. i prefer leaving tacacs out until i confirm that i can reach tacacs servers when the device in the network.
