ACS 5.3 EAP-TLS Machine authentication with AD - Failed with 24492
PC Tiya
We successfully configured EAP-TLS on the ACS (5.3) for machine authentication using certificate only. I then would like ACS to check whether the machine is in a specific group in AD before permitting the access. The ACS has failed "Machine authentication against AD" code 24492 for all Windows clients, but it works for Mac machines (Yes, those Mac are joining to AD).
What we have configured so far,
- Users and Identity Stores > External Identity Stores > Active Directory
     - Enabled Machine authentication
     - Select Group name that machines reside
- Users and Identity Stores > External Identity Stores > Ceritificate Authentication Profile, Principal Username X509: Subject Alternative Name
- Access Policies > Access Services > [ServiceA], Allowed Protocols, Enabled Process Host Lookup, Allow EAP-TLS
     - Create Identity rule to match the Subject and result the Authentication Profile created above then AD
     - Create Authorization rule to match the AD group created above
The ACS returned
RADIUS Request dropped : 24492 Machine authentication against Active Directory has failed
As far as I can tell, it hit the identity rule, extracted the SAN, but failed to look up on AD. The above configuration works for Mac machines.
Can anyone shed some light on this?
PC Tiya
Anyone?
Below are the Steps of the authentication details
11001 Received RADIUS Access-Request
11017 RADIUS created a new session
Evaluating Service Selection Policy
15004 Matched rule
15012 Selected Access Service - Wireless AD Authentication
11507 Extracted EAP-Response/Identity
12500 Prepared EAP-Request proposing EAP-TLS with challenge
11006 Returned RADIUS Access-Challenge
11018 RADIUS is re-using an existing session
12502 Extracted EAP-Response containing EAP-TLS challenge-response and accepting EAP-TLS as negotiated
12800 Extracted first TLS record; TLS handshake started.
12805 Extracted TLS ClientHello message.
12806 Prepared TLS ServerHello message.
12807 Prepared TLS Certificate message.
12809 Prepared TLS CertificateRequest message.
12505 Prepared EAP-Request with another EAP-TLS challenge
12504 Extracted EAP-Response containing EAP-TLS challenge-response
12811 Extracted TLS Certificate message containing client certificate.
12812 Extracted TLS ClientKeyExchange message.
12813 Extracted TLS CertificateVerify message.
12804 Extracted TLS Finished message.
12801 Prepared TLS ChangeCipherSpec message.
12802 Prepared TLS Finished message.
12816 TLS handshake succeeded.
12509 EAP-TLS full handshake finished successfully
Evaluating Identity Policy
15004 Matched rule
22037 Authentication Passed
22023 Proceed to attribute retrieval
24433 Looking up machine/host in Active Directory - COMPUTERNAME$@DOMAIN
24492 Machine authentication against Active Directory has failed.
22059 The advanced option that is configured for process failure is used.
22062 The 'Drop' advanced option is configured in case of a failed authentication request.
Jatin Katyal
Is the machine authentication with eap-tls not working for Machintosh machines and working for windows machines?
~BR
Jatin Katyal
**Do rate helpful posts**
~Jatin
No. It is the other way round which is quite bizarre. It is working for Mac machines joining to the doamin, but not Windows.
