10-26-2016 07:13 AM - edited 03-11-2019 12:11 AM
I cant see the MAC filter configured in ACS using IExplorer11 but if i use IE10 i can see this filter. Is there any problem in WebUI using IE11??
10-26-2016 02:50 PM
If you can send the screenshot from ACS, which option are you looking for.
Also let me know the ACS version.
10-27-2016 01:09 AM
10-27-2016 03:29 AM
There is no such bug for it. If you could confirm your ACS version.
We can check for compatibility of browsers.
Otherwise need to correct the database of ACS.
10-26-2016 03:59 PM
ACS 5.5 or higher should support IE11.
In general, ACS - especially earlier 5.x versions - has been very particular about using only supported browsers. It was as bad as causing database corruption when making changes using an unsupported browser version!
