01-27-2005 10:27 AM - edited 03-10-2019 01:59 PM
We use ACS and RSA to control access for RAS, VPN, and network devices. However, for ACS management login http://acsserver:2002, we use login defined in ACS administration panel. Is there anyway to login to ACS management web using external authentication such as RSA or Windows domain? By the way we are running ACS Release 3.3(1) Build 16. Thanks in advance.
01-27-2005 08:25 PM
ACS only supports local administrator accounts. You will not be able to use RSA or Windows.
Faris
01-31-2005 09:16 AM
Thanks for the info. I guess it makes sense since, when the external authentication breaks one won't be able to logon to ACS to fix it... Then again fall back could be implemented to local incase of such. Anyway, thanks again for quick reply.
