CoA is not working using Cisco ISE 1.1
sachpednekar
Hi all,
Can anyone help me in resolving CoA using cisco ISE as getting below error
Radius authentication failed for USER: CALLING STATION ID: 44:37:E6:4A:A7:56 AUTHTYPE:
6 Replies 6
jan.nielsen
Level 7
Level 7
Did you configure youre ise servers as clients in the switch ?
aaa server radius dynamic-author
client server-key
yes
client 162.12.95.167 server-key 7 0518090E2A151D02380E3651
client 162.12.28.135 server-key 7 095F4108125C44192A072569
both are psn
do i need to make an entry of Admin node as well
these are in distributed deployment
No, just the psn's
Is there a firewall in between. Can you check and see if you are allowing ports 1700 and 3799?
In the packet captures I have seen only port 1700.
Tarik Admani
*Please rate helpful posts*
Below ports i have opend!
ISE Firewall ruleset
SourceDestinationPort no *DescriptionUse
10.120.166.13(Prim Admin)10.120.182.131521
UDP 161
443
80
10.120.182.13(Primary Monitoring)10.120.166.131521
UDP 161
443
80
162.12.95.167(PSN)
162.12.28.135(PSN)
162.12.189.135(PSN)
10.120.166.13
10.120.182.13
1521
UDP 161
10.120.166.13
10.120.182.13
162.12.95.167
162.12.28.135
162.12.189.135
1521
UPD 161
443
80
10.120.166.1310.120.182.1322
10.120.166.1310.120.182.131812
10.120.166.1310.120.182.131813
10.120.166.1310.120.182.13ICMP
10.120.166.1310.120.182.13UDP 20514
10.120.166.1310.120.182.131700
10.120.166.1310.120.182.133799
10.120.166.1310.120.182.1369
10.120.166.1310.120.182.13UDP 514
10.120.182.1310.120.166.1322
10.120.182.1310.120.166.131812
10.120.182.1310.120.166.131813
10.120.182.1310.120.166.13ICMP
10.120.182.1310.120.166.13UDP 20514
10.120.182.1310.120.166.131700
10.120.182.1310.120.166.133799
10.120.182.1310.120.166.1369
10.120.182.1310.120.166.13UDP 514
162.12.0.0/16
10.120.166.21
10.120.166.22
10.120.166.13
10.120.182.13
port 80/443HTTP/HTTPSURL-redirection
162.12.0.0/1610.120.166.13
10.120.182.13
1812RFC Standard
10.120.182.13
1813
10.120.166.13
10.120.182.13
162.12.0.0/161812RFC Standard
10.120.166.13
10.120.182.13
162.12.0.0/161813
10.120.166.13
10.120.182.13
162.12.95.167
162.12.28.135
162.12.189.135
22SSH
162.12.0.0/16
10.120.166.21
10.120.166.22
10.120.166.13
10.120.182.13
22SSH
10.120.166.13
10.120.182.13
162.12.0.0/16
10.120.166.21
10.120.166.22
ICMPPing
162.12.0.0/16
10.120.166.21
10.120.166.22
10.120.166.13
10.120.182.13
ICMPPing
162.12.95.167
162.12.28.135
162.12.189.135
10.120.166.13
10.120.182.13
20514UDPSyslog Transport
10.120.166.13
10.120.182.13
162.12.95.167
162.12.28.135
162.12.189.135
10.120.166.13
10.120.182.13
162.12.95.167
162.12.28.135
162.12.189.135
1700IOS Default
162.12.95.167
162.12.28.135
162.12.189.135
10.120.166.13
10.120.182.13
1700IOS Default
162.12.95.167
162.12.28.135
162.12.189.135
10.120.166.13
10.120.182.13
3799RFC
10.120.166.13
10.120.182.13
162.12.95.167
162.12.28.135
162.12.189.135
3799RFC
10.120.182.13
8443TCP
10.120.134.74
10.120.135.74
10.120.166.13
10.120.182.13
UDP/TCP 53DNS
10.120.166.13
10.120.182.13
10.120.134.74
10.120.135.74
UDP/TCP 53DNS
10.120.166.13
10.120.182.13
10.120.132.166
10.120.133.166
10.120.134.5
10.120.135.5
10.120.135.4
UDP 123NTP
10.120.132.166
10.120.133.166
10.120.134.5
10.120.135.5
10.120.135.4
10.120.166.13
10.120.182.13
UDP 123NTP
10.120.166.13
10.120.182.13
162.12.95.170UDP/TCP 514Syslog
10.120.129.135
10.120.134.5
10.120.135.5
10.120.135.4
10.120.166.13
10.120.182.13
UDP/TCP 636Secure LDAP
10.120.129.135
10.120.134.5
10.120.135.5
10.120.135.4
10.120.166.13
10.120.182.13
UDP/TCP 389LDAP
10.120.166.13
10.120.182.13
10.120.129.135
10.120.134.5
10.120.135.5
10.120.135.4
10.120.166.13
10.120.182.13
10.120.129.135
10.120.134.5
10.120.135.5
10.120.135.4
UDP/TCP 389LDAP
162.12.95.167
162.12.28.135
162.12.189.135
10.120.166.13
10.120.182.13
UDP 69TFTP
10.120.166.13
10.120.182.13
162.12.95.167
162.12.28.135
162.12.189.135
UDP 69TFTP
10.120.166.21
10.120.166.22
162.12.95.167
162.12.28.135
162.12.189.135
10.120.166.13
10.120.182.13
UDP 69TFTP
162.12.95.167
162.12.28.135
162.12.189.135
10.120.166.13
10.120.182.13
10.120.166.21
10.120.166.22
UDP 69TFTP
162.12.0.0/16
10.120.166.21
10.120.166.22
10.120.166.13
10.120.182.13
8080WWW
10.120.134.5
10.120.135.5
10.120.135.4
10.120.166.13
10.120.182.13
445SMBAD Domain services
10.120.134.5
10.120.135.5
10.120.135.4
10.120.166.13
10.120.182.13
88KDCAD Domain services
10.120.134.5
10.120.135.5
10.120.135.4
10.120.166.13
10.120.182.13
3268Global CatalogAD Domain services
10.120.134.5
10.120.135.5
10.120.135.4
10.120.166.13
10.120.182.13
464KPASSAD Domain services
10.120.166.13
10.120.182.13
10.120.134.5
10.120.135.5
10.120.135.4
10.120.166.13
10.120.182.13
10.120.134.5
10.120.135.5
10.120.135.4
10.120.166.13
10.120.182.13
10.120.134.5
10.120.135.5
10.120.135.4
10.120.166.13
10.120.182.13
10.120.134.5
10.120.135.5
10.120.135.4
Web autherization working and and i am able to authenticate but if i open any other url then it redirect me again to ISE web Auth page....
Troubleshoot Authentication Opens in new window
View Diagnostic Messages
Audit Network Device Configuration Opens in new window
View Network Device Configuration Opens in new window
View Server Configuration Changes
Authentication Summary
Logged At:
November 21,2012 2:16:11.794 PM
RADIUS Status:
Authentication succeeded
NAS Failure:
Username:
00:21:CC:69:3D:30
MAC/IP Address:
00:21:CC:69:3D:30
Network Device:
FarmingtonHills : 162.12.95.71 : GigabitEthernet2/0/18
Allowed Protocol:
Default Network Access
Identity Store:
Authorization Profiles:
TDAF-WebAuth
SGA Security Group:
Authentication Protocol :
Lookup
Authentication Result
User-Name=00-21-CC-69-3D-30
State=ReauthSession:A20C5F47000000970ED72ABE
Class=CACS:A20C5F47000000970ED72ABE:ISEHQFM01/142798580/98
Termination-Action=RADIUS-Request
cisco-av-pair=url-redirect-acl=ACL-TDAF-WEBAUTH-REDIRECT
cisco-av-pair=url-redirect=https://ISEHQFM01.tcom.tdaf.com:8443/guestportal/gateway?sessionId=A20C5F47000000970ED72ABE&action=cwa
Related Events
Nov 21,12 2:16:18.090 PM
Radius accounting start
Nov 21,12 2:16:17.012 PM
Radius accounting stop
Radius accouting stop
Nov 21,12 2:16:11.895 PM
Authentication Details
Logged At:
Occurred At:
November 21,2012 2:16:11.793 PM
Server:
ISEHQFM01
Authentication Method:
mab
EAP Authentication Method :
Lookup
EAP Tunnel Method :
Username:
00:21:CC:69:3D:30
RADIUS Username :
00:21:CC:69:3D:30
Calling Station ID:
00:21:CC:69:3D:30
Framed IP Address:
162.12.108.160
Use Case:
Host Lookup
Network Device:
FarmingtonHills
Network Device Groups:
Location#All Locations#Farmington Hills MI,Device Type#All Device Types
NAS IP Address:
162.12.95.71
NAS Identifier:
NAS Port:
50218
NAS Port ID:
NAS Port Type:
Ethernet
Allowed Protocol:
Service Type:
Call Check
Identity Store:
TDAF-WebAuth
Active Directory Domain:
Identity Group:
Allowed Protocol Selection Matched Rule:
MAB
Identity Policy Matched Rule:
Default
Selected Identity Stores:
Internal Endpoints
Authorization Policy Matched Rule:
Default
SGA Security Group:
AAA Session ID:
Audit Session ID:
Tunnel Details:
Cisco-AVPairs:
service-type=Call Check
audit-session-id=A20C5F47000000970ED72ABE
Other Attributes:
ConfigVersionId=8,DestinationPort=1812,Protocol=Radius,Framed-MTU=1500,EAP-Key-Name=,CPMSessionID=A20C5F47000000970ED72ABE,EndPointMACAddress=00-21-CC-69-3D-30,Device Type=Device Type#All Device Types,Location=Location#All Locations#Farmington Hills MI,Model Name=Cisco,Device IP Address=162.12.95.71,Called-Station-ID=28:94:0F:0C:06:92
Posture Status:
Pending
EPS Status:
Steps
11001 Received RADIUS Access-Request
11017 RADIUS created a new session
11027 Detected Host Lookup UseCase (Service-Type = Call Check (10))
Evaluating Service Selection Policy
15048 Queried PIP
15048 Queried PIP
15004 Matched rule
Evaluating Identity Policy
15006 Matched Default Rule
15013 Selected Identity Store - Internal Endpoints
24209 Looking up Host in Internal Hosts IDStore - 00:21:CC:69:3D:30
24217 The host is not found in the internal endpoints identity store
22056 Subject not found in the applicable identity store(s)
22058 The advanced option that is configured for an unknown user is used
22060 The 'Continue' advanced option is configured in case of a failed authentication request
Evaluating Authorization Policy
15004 Matched rule
15016 Selected Authorization Profile - TDAF-WebAuth
11002 Returned RADIUS Access-Accept
Tarik Admani
I apologize for the question but I am viewing this from my mobile device. Please make surw that coa and is opened between the access layer device and the ise psn group.
Thanks.
Sent from Cisco Technical Support Android App
