doit1x Monitor Mode
I have a setup with a were I configured monitor mode on a switch with ISE as RADIUS server. This is for testing before a bigger deployment at a customer site.
Im using ISE 1.1.3, C2960 and IOS 15.0(2) and a laptop with Windows 7 Enterprise SP1.
The correct configuration with EAP-TLS and machin cert is working like it should but it is when I remove this and make the laptop fail that I get wierd results with monitor mode. I cant get DNS to work in dot1x monitor mode if the client fail authentication.
When the client fail dot1x and MAB it gets a IP with DHCP. I can ping but DNS/browsing is not working. If I put the AuthC back and the client authenticates DNS is working, or if I turn of dot1x on the client then DNS work as it should.
Anyone has seen this before and/or have some insight on how this should work?
I know this probably is a client/supplicant problem.
Port config:
interface GigabitEthernet0/2
description 802.1x port PC lab
switchport access vlan 8
switchport mode access
authentication host-mode multi-auth
authentication open
authentication port-control auto
authentication violation restrict
mab
dot1x pae authenticator
sw#sh auth sess int gi0/2
            Interface:  GigabitEthernet0/2
          MAC Address:  000d.9d90.c96d
           IP Address:  192.168.50.30
            User-Name:  000d9d90c96d
               Status:  Authz Failed
               Domain:  DATA
       Oper host mode:  multi-auth
     Oper control dir:  both
      Session timeout:  N/A
         Idle timeout:  N/A
    Common Session ID:  C0A8320900000CF4DC2FDA59
      Acct Session ID:  0x00000D2A
               Handle:  0xA0000CF5
Runnable methods list:
       Method   State
       dot1x    Failed over
       mab      Failed over
gschmitt.ngit
You need a configured ip access-group with the ACL of permit ip any any hardcoded on the interface.
askhuran
While checking the authenticating the sessions, please also verify all  the dACLs which are enforced. This will help obtain more input and  narrow down the problem.  Please make sure that the Web-auth ACL has no  errors
Octavian Szolga
Level 4
Level 4
Please check if you configured Fallback to unauthorized network access under you Windows NIC dot1x settings.
If not, you won't get network access when dot1x fails.
