In ISE (ise-3315) low reliability
Vlad Voronko
Hello.
What will happen if ise- 3315 broke one HDD? In ISE low reliability - RAID no. How can a server for security do without RAID?
How can we improve reliability?
8 Replies 8
Tarik Admani
You can purchase another appliance and run them in a distributed deployment, where one is failover, and the other is standby. Or you can upgrade to the 3355 which has the raid controller.
Tarik Admani
So sorry. Unfortunately, we already bought ise-3315. We'll do the cluster. I think nowadays the possibility RAID1 on the server must be a priori. Thanks Tarik.
nspasov
You just bought the low end appliance One thing to also consider is that you can have additional nodes running in VM Ware...if you don't want to purchase additional hardware
Thank you for rating!
Naveen Kumar
Level 4
Level 4
For the reliability in ISE, you need to buy one more ISE same appliance.
Ravi Singh
Level 7
Level 7
You have to purchase a new 3315 device and deploy ISE in distributed  environment and configure HA. For configuring HA you can see Configuring Administration Cisco ISE Nodes for High Availability
muhammk2
Even  if the RAID option is present, two appliances should be bought to configure them  in HA, so that operations are not disturbed in case any issue occurs  and one of the box goes down due to any issue other than HDD.
harvisin
Level 3
Level 3
Hello Vlad,
I think that you might have got your answer from the above SME's , yes they are absolutely correct that you need to go for High Availabiity for more realibility that can be either with the two hardware appliances or with the two ISE in the virtual environment.
kaaftab
Level 4
Level 4
The best solution is going for the higher appliance or VMware solution for reference kindly see the following details
Cisco Identity Services Engine Hardware Specifications
Cisco Identity Services Engine Appliance 3315 (Small)
Cisco Identity Services Engine Appliance 3355 (Medium)
Cisco Identity Services Engine Appliance 3395 (Large)
Processor
1 x QuadCore Intel Core 2 CPU Q9400 @ 2.66 GHz
1 x QuadCore Intel Xeon CPU E5504 @ 2.00 GHz
2 x QuadCore Intel Xeon CPU E5504 @ 2.00 GHz
Memory
4 GB
4 GB
4 GB
Hard disk
2 x 250-GB SATA HDD
2 x 300-GB SAS drives
4 x 300-GB SFF SAS drives
RAID
No
Yes (RAID 0)
Yes (RAID 0+1)
Removable media
CD/DVD-ROM drive
CD/DVD-ROM drive
CD/DVD-ROM drive
Network Connectivity
Ethernet NICs
4 x Integrated Gigabit NICs
10BASE-T cable support
Cat 3, 4, or 5 unshielded twisted pair (UTP) up to 328 ft (100 m)
Cat 3, 4, or 5 UTP up to 328 ft (100 m)
10/100/1000BASE-TX cable support
Cat 5 UTP up to 328 ft (100 m)
Secure Sockets Layer (SSL) accelerator card
None
Cavium CN1620-400-NHB-G
Interfaces
Serial ports
USB 2.0 ports
4 (two front, two rear)
4 (one front, one internal, two rear)
Video ports
External SCSI ports
None
None
None
System Unit
Form factor
Rack-mount 1 RU
Rack-mount 1 RU
Rack-mount 1 RU
Weight
28 lb (12.7 kg) fully configured
35 lb (15.87 kg) fully configured
Dimensions (H x W x L)
1.69 x 17.32 x 22 in.
(43 x 440 x 55.9 mm)
1.69 x 17.32 x 27.99 in.
(43 x 42.62 x 711 mm)
Power supply
350W
Dual 675W (redundant)
Cooling fans
6; non-hot plug, nonredundant
9; redundant
9; redundant
BTU rating
1024 BTU/hr (at 300W)
2661 BTU/hr (at 120V)
Compliance
FIPS
Uses FIPS 140-2 Level 1 validated cryptographic modules
Cisco Secure Network Server 3415 (Small) - New
Cisco Secure Network Server 3495 (Large) - New
Processor
1 x Intel Xenon Quad-Core 2.4 GHz E5-2609
2 x Intel Xenon Quad-Core 2.4 GHz E5-2609
Memory
16 GB
32 GB
Hard disk
1 x 600GB 6Gb SAS 10K RPM
2 x 600GB 6Gb SAS 10K RPM
RAID
No
Yes (RAID 0+1)
CD/DVD-ROM drive
No
No
Ethernet NICs
None
Interfaces
Front Panel Connector
1 x KVM console connector (supplies 2 USB, 1 VGA, and 1 serial connector)
Additional Rear Connectors
Additional  interfaces including a VGA video port, 2 USB 2.0 ports, an RJ45 serial  port, 1 Gigabit Ethernet management port, and dual 1 Gigabit Ethernet  ports
System Unit
Form factor
Rack-mount 1 RU
Rack-mount 1 RU
Weight
35.6 lbs (16.2 kg)
26.8 lbs (12.1 kg)
1.7 x 16.9 x 28.5 in.
(4.32 x 43 x 72.4 cm)
Power supply
650W
Dual 650W (redundant)
Cooling fans
Temperature: Operating
32 to 104°F (0 to 40°C) (operating, sea level, no fan fail, no CPU throttling, turbo mode)
Temperature: Nonoperating
-40 to 158°F (-40 to 70°C)
Compliance
FIPS
