ISE 1.2 patch 5 My devices portal not showing regsitered devices
Kabir Ibrahim
Hello Guys,
I am running ISE 1.2 with all recent patches installed. I have a weird issue where AD users login to mydevices portal and are not able to view any of their registered devices. even thou the devices were successfully registered and onboarded.
Saurav Lodh
Level 7
Level 7
Can you see them in registered devices , in internal endpoints from ISE database? can you delete them and onboard them again.
Check your synchronization between your ise nodes, i had a similar issue, that was because ntp had been down for a while, and then the nodes didn't sync the device registrations, and guest users between the nodes.
nspasov
Upgrade to patch 6 as soon as you can. I had all kinds of issues with 5 in my lab.
**Thank you for rating helpful posts**
