ISE hot spot with multiple tokens
zappo0305
We got ISE recently and we want to deploy wireless conference sing hot-spot.
My question is, when creating a hot-spot, can we create multiple tokens?
i.e. I have 3 conferences at the same time, each one at different location , thus I want to create 3 tokens (one for each conference).
Ive heard that you need license and MSE etc.. but not sure whether this is true.
Much appreciate for your time.
jan.nielsen
Level 7
Level 7
If your locations are defined as AP groups in your WLC, then i think you should be able to use the nas-id setting under your AP group in the request to ISE from the radius nas-id attribute, and then use that in your authorization policy to redirect guests to different guest portals, which can then have different passwords (assuming that what you mean by "tokens"). MSE is only needed if you need actual location from a map in MSE
