Microsft NPS for Cisco Device Authentication
matt.hyland
Hi, I have a sititation where I need to use a central Microsoft NPS server to secure Cisco devices across multiple sites. Each site has there own IT team who can access their equipment but shouldn't be able to access another sites equipment.
I have created the policies on NPS with the appropriate AD groups, and then tried to use the condition 'Access Client IPv4 Address' and limit this to the sites IP range e.g. 192.168.5.*.
However with this condition in place the authentication fails, when i remove this condition authenticaion works but without the limitiations I need. I have looked through these forums and many others but can't find a solution that seems to work.
Has anyone needed to do anything similar, or had a similar issue to this? If so how did you resolve it?
Thanks!
Are you trying to restrict based on the source IP address of the client PC? I don't think that will work, the NPS server will only see the source IP address of the switch in the radius request.
You could create multiple authentication rules e.g - "AD group Site 1 IT Admin" + "NAS IPv4 Address = 192.168.5.*" condition, this would permit only those users in that group logging into the IP address you define for Site 1. You could then create additional rules to match for another AD group matching the other sites' subnets.
You could also restrict access to logging into the devices belonging to the site, by applying an ACL to the VTY line of the devices, permitting only the local subnets and denying all else.
