Bookmark
Subscribe
691
My users cant connect using cli to my 2921 router, can i get help with this?
Rwhjr0760
Hello All... i
I have configured this router to have users sign in to the router. i would eventually like to have them using ssh only, and only be able to show config, and edit the nat table for the IP addresses that they are testing? i wonder if someone can help with this task. i seem to have something wrong as, they get a message when they sign into the router from telnet:
pss2900#show config
% Invalid input detected at '^' marker.
User Access Verification
Username: admin
Password:
pss2900#
pss2900#
pss2900#
pss2900#sho run
Building configuration...
Current configuration : 21365 bytes
! Last configuration change at 11:28:58 UTC Tue Aug 12 2014 by admin
! NVRAM config last updated at 11:28:51 UTC Tue Aug 12 2014 by admin
version 15.1
hostname pss2900
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
no ipv6 cef
ip source-route
ip cef
no ip domain lookup
ip domain name mh.lucent.com
crypto pki trustpoint TP-self-signed-1294994828
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-1294994828
 revocation-check none
 rsakeypair TP-self-signed-1294994828
crypto pki certificate chain TP-self-signed-1294994828
 certificate self-signed 01
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 31323934 39393438 3238301E 170D3132 31303031 32323031
  35335A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D31 32393439
  39343832 3830819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  81009399 7D875CDA 650A5D94 9156B539 D5F64EA4 1BE03FDA 2AF9096D 8277C7E8
  623B715B 4EA64C45 8295567C BB01E5C7 75AE61D4 4953718F C584B309 153B1048
  BB9282B7 97AE1A11 60C0B980 9367F926 66E33164 537F9050 34FD8311 A0FF0BBD
  AF93DACA 21E6CF42 936F441D FB04DC6E 420ADC4D 9B41568E B84D6FCA 270E6B31
  50690203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
  551D2304 18301680 1423299B 86480D8D 6542E0AA E5CB754F 6B579AA8 32301D06
  03551D0E 04160414 23299B86 480D8D65 42E0AAE5 CB754F6B 579AA832 300D0609
  2A864886 F70D0101 05050003 81810000 213880EB 11C4586F B17AC875 B3F12AFC
  56E0A627 E57FF8EA AD65C652 738B9997 6F064E55 60CDE61A 0D1E0AEA FC0DAFFA
  210A3054 AF44B5ED 8AA553F5 14D76694 7464F894 97F221C5 7F5EA21E 9C6130F6
  2814BDAF 6AA93068 CBD6AB47 07CE75D1 CA1CFA66 F5171AC4 0A9C4D65 22188970
  C6DD8F6F 85AAE0DC DDE3C097 F60909
        quit
license udi pid CISCO2921/K9 sn FTX1640AHNF
username admin privilege 15 password 0 3xtremes
username frank privilege 7 password 0 feather
username jananee privilege 7 password 0 ramani
username kiran privilege 15 password 0 kandi
interface Loopback0
 ip address 200.200.200.200 255.255.255.255
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
 ip address 135.112.155.249 255.255.255.0
 ip directed-broadcast
 ip nat outside
 ip virtual-reassembly in
 duplex full
 speed 1000
interface GigabitEthernet0/1
 ip address 192.168.0.1 255.255.240.0
 ip nat inside
 duplex full
 speed 1000
interface GigabitEthernet0/2
 description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/2$
 no ip address
 shutdown
 duplex full
 speed 1000
router ospf 200
 network 10.20.2.0 0.0.0.0 area 0
 network 10.20.5.0 0.0.0.0 area 0
 network 192.168.0.1 0.0.0.0 area 0
 network 200.200.200.200 0.0.0.0 area 0
ip default-gateway 135.112.155.1
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface GigabitEthernet0/1 overload
ip nat inside source static 192.168.5.11 135.112.155.11
ip nat inside source static 192.168.5.12 135.112.155.12
ip nat inside source static 192.168.5.13 135.112.155.13
ip nat inside source static 192.168.5.14 135.112.155.14
ip nat inside source static 192.168.5.15 135.112.155.15
ip nat inside source static 192.168.5.16 135.112.155.16
ip nat inside source static 192.168.5.17 135.112.155.17
ip nat inside source static 192.168.5.18 135.112.155.18
ip nat inside source static 192.168.5.19 135.112.155.19
ip nat inside source static 192.168.5.20 135.112.155.20
ip nat inside source static 192.168.5.21 135.112.155.21
ip nat inside source static 192.168.5.22 135.112.155.22
ip nat inside source static 192.168.5.23 135.112.155.23
ip nat inside source static 192.168.5.24 135.112.155.24
ip nat inside source static 192.168.5.25 135.112.155.25
ip nat inside source static 192.168.5.26 135.112.155.26
ip nat inside source static 192.168.5.27 135.112.155.27
ip nat inside source static 192.168.5.28 135.112.155.28
ip nat inside source static 192.168.5.29 135.112.155.29
ip nat inside source static 192.168.5.30 135.112.155.30
ip nat inside source static 192.168.5.31 135.112.155.31
ip nat inside source static 192.168.5.32 135.112.155.32
ip nat inside source static 10.20.5.33 135.112.155.33
ip nat inside source static 192.168.5.34 135.112.155.34
ip nat inside source static 192.168.5.35 135.112.155.35
ip nat inside source static 192.168.5.36 135.112.155.36
ip nat inside source static 192.168.5.37 135.112.155.37
ip nat inside source static 10.20.5.38 135.112.155.38
ip nat inside source static 192.168.5.39 135.112.155.39
ip nat inside source static 192.168.5.40 135.112.155.40
ip nat inside source static 192.168.5.41 135.112.155.41
ip nat inside source static 192.168.5.42 135.112.155.42
ip nat inside source static 192.168.5.43 135.112.155.43
ip nat inside source static 10.20.5.44 135.112.155.44
ip nat inside source static 192.168.5.45 135.112.155.45
ip nat inside source static 192.168.5.46 135.112.155.46
ip nat inside source static 192.168.5.47 135.112.155.47
ip nat inside source static 192.168.5.48 135.112.155.48
ip nat inside source static 192.168.5.49 135.112.155.49
ip nat inside source static 192.168.5.50 135.112.155.50
ip nat inside source static 192.168.5.51 135.112.155.51
ip nat inside source static 192.168.5.52 135.112.155.52
ip nat inside source static 192.168.5.53 135.112.155.53
ip nat inside source static 192.168.5.54 135.112.155.54
ip nat inside source static 192.168.5.55 135.112.155.55
ip nat inside source static 192.168.5.56 135.112.155.56
ip nat inside source static 192.168.5.57 135.112.155.57
ip nat inside source static 10.20.5.58 135.112.155.58
ip nat inside source static 192.168.5.59 135.112.155.59
ip nat inside source static 192.168.5.60 135.112.155.60
ip nat inside source static 192.168.5.61 135.112.155.61
ip nat inside source static 192.168.5.62 135.112.155.62
ip nat inside source static 192.168.5.63 135.112.155.63
ip nat inside source static 192.168.5.64 135.112.155.64
ip nat inside source static 192.168.5.65 135.112.155.65
ip nat inside source static 192.168.5.66 135.112.155.66
ip nat inside source static 192.168.5.67 135.112.155.67
ip nat inside source static 192.168.5.68 135.112.155.68
ip nat inside source static 192.168.5.69 135.112.155.69
ip nat inside source static 10.20.5.70 135.112.155.70
ip nat inside source static 192.168.5.71 135.112.155.71
ip nat inside source static 192.168.5.72 135.112.155.72
ip nat inside source static 192.168.5.73 135.112.155.73
ip nat inside source static 192.168.5.74 135.112.155.74
ip nat inside source static 10.20.5.75 135.112.155.75
ip nat inside source static 10.20.5.76 135.112.155.76
ip nat inside source static 192.168.5.77 135.112.155.77
ip nat inside source static 10.20.5.78 135.112.155.78
ip nat inside source static 192.168.5.79 135.112.155.79
ip nat inside source static 192.168.5.80 135.112.155.80
ip nat inside source static 192.168.5.81 135.112.155.81
ip nat inside source static 192.168.5.82 135.112.155.82
ip nat inside source static 192.168.5.83 135.112.155.83
ip nat inside source static 192.168.5.84 135.112.155.84
ip nat inside source static 192.168.5.85 135.112.155.85
ip nat inside source static 192.168.5.86 135.112.155.86
ip nat inside source static 192.168.5.87 135.112.155.87
ip nat inside source static 192.168.5.88 135.112.155.88
ip nat inside source static 192.168.5.89 135.112.155.89
ip nat inside source static 192.168.5.90 135.112.155.90
ip nat inside source static 192.168.5.91 135.112.155.91
ip nat inside source static 192.168.5.92 135.112.155.92
ip nat inside source static 192.168.5.93 135.112.155.93
ip nat inside source static 192.168.5.94 135.112.155.94
ip nat inside source static 192.168.5.95 135.112.155.95
ip nat inside source static 192.168.5.96 135.112.155.96
ip nat inside source static 192.168.5.97 135.112.155.97
ip nat inside source static 192.168.5.98 135.112.155.98
ip nat inside source static 192.168.5.99 135.112.155.99
ip nat inside source static 192.168.5.100 135.112.155.100
ip nat inside source static 192.168.5.101 135.112.155.101
ip nat inside source static 192.168.5.102 135.112.155.102
ip nat inside source static 192.168.5.103 135.112.155.103
ip nat inside source static 192.168.5.104 135.112.155.104
ip nat inside source static 192.168.5.105 135.112.155.105
ip nat inside source static 192.168.5.106 135.112.155.106
ip nat inside source static 192.168.5.107 135.112.155.107
ip nat inside source static 192.168.5.108 135.112.155.108
ip nat inside source static 192.168.5.109 135.112.155.109
ip nat inside source static 192.168.5.110 135.112.155.110
ip nat inside source static 192.168.5.111 135.112.155.111
ip nat inside source static 192.168.5.112 135.112.155.112
ip nat inside source static 192.168.5.113 135.112.155.113
ip nat inside source static 192.168.5.114 135.112.155.114
ip nat inside source static 192.168.5.115 135.112.155.115
ip nat inside source static 192.168.5.116 135.112.155.116
ip nat inside source static 192.168.5.117 135.112.155.117
ip nat inside source static 192.168.5.118 135.112.155.118
ip nat inside source static 192.168.5.119 135.112.155.119
ip nat inside source static 192.168.5.120 135.112.155.120
ip nat inside source static 192.168.5.121 135.112.155.121
ip nat inside source static 192.168.5.122 135.112.155.122
ip nat inside source static 192.168.5.123 135.112.155.123
ip nat inside source static 192.168.5.124 135.112.155.124
ip nat inside source static 192.168.5.125 135.112.155.125
ip nat inside source static 192.168.5.126 135.112.155.126
ip nat inside source static 192.168.5.127 135.112.155.127
ip nat inside source static 192.168.5.128 135.112.155.128
ip nat inside source static 192.168.5.129 135.112.155.129
ip nat inside source static 192.168.5.130 135.112.155.130
ip nat inside source static 192.168.5.131 135.112.155.131
ip nat inside source static 192.168.5.132 135.112.155.132
ip nat inside source static 192.168.5.133 135.112.155.133
ip nat inside source static 192.168.5.134 135.112.155.134
ip nat inside source static 192.168.5.135 135.112.155.135
ip nat inside source static 192.168.5.136 135.112.155.136
ip nat inside source static 192.168.5.137 135.112.155.137
ip nat inside source static 192.168.5.138 135.112.155.138
ip nat inside source static 192.168.5.139 135.112.155.139
ip nat inside source static 192.168.5.140 135.112.155.140
ip nat inside source static 192.168.5.141 135.112.155.141
ip nat inside source static 192.168.5.142 135.112.155.142
ip nat inside source static 192.168.5.143 135.112.155.143
ip nat inside source static 192.168.5.144 135.112.155.144
ip nat inside source static 192.168.5.145 135.112.155.145
ip nat inside source static 192.168.5.146 135.112.155.146
ip nat inside source static 192.168.5.147 135.112.155.147
ip nat inside source static 192.168.5.148 135.112.155.148
ip nat inside source static 192.168.5.149 135.112.155.149
ip nat inside source static 192.168.5.150 135.112.155.150
ip nat inside source static 192.168.5.151 135.112.155.151
ip nat inside source static 192.168.5.152 135.112.155.152
ip nat inside source static 192.168.5.153 135.112.155.153
ip nat inside source static 192.168.5.154 135.112.155.154
ip nat inside source static 192.168.5.155 135.112.155.155
ip nat inside source static 192.168.5.156 135.112.155.156
ip nat inside source static 192.168.5.157 135.112.155.157
ip nat inside source static 192.168.5.158 135.112.155.158
ip nat inside source static 192.168.5.159 135.112.155.159
ip nat inside source static 10.20.5.160 135.112.155.160
ip nat inside source static 192.168.5.161 135.112.155.161
ip nat inside source static 192.168.5.162 135.112.155.162
ip nat inside source static 192.168.5.163 135.112.155.163
ip nat inside source static 192.168.5.164 135.112.155.164
ip nat inside source static 192.168.5.165 135.112.155.165
ip nat inside source static 192.168.5.166 135.112.155.166
ip nat inside source static 10.20.5.167 135.112.155.167
ip nat inside source static 192.168.5.168 135.112.155.168
ip nat inside source static 192.168.5.169 135.112.155.169
ip nat inside source static 192.168.5.170 135.112.155.170
ip nat inside source static 192.168.5.171 135.112.155.171
ip nat inside source static 192.168.5.172 135.112.155.172
ip nat inside source static 192.168.5.173 135.112.155.173
ip nat inside source static 192.168.5.174 135.112.155.174
ip nat inside source static 192.168.5.175 135.112.155.175
ip nat inside source static 192.168.5.176 135.112.155.176
ip nat inside source static 192.168.5.177 135.112.155.177
ip nat inside source static 192.168.5.178 135.112.155.178
ip nat inside source static 192.168.5.179 135.112.155.179
ip nat inside source static 192.168.5.180 135.112.155.180
ip nat inside source static 192.168.5.181 135.112.155.181
ip nat inside source static 192.168.15.182 135.112.155.182
ip nat inside source static 192.168.5.183 135.112.155.183
ip nat inside source static 192.168.5.184 135.112.155.184
ip nat inside source static 192.168.5.185 135.112.155.185
ip nat inside source static 192.168.5.186 135.112.155.186
ip nat inside source static 192.168.5.187 135.112.155.187
ip nat inside source static 192.168.15.188 135.112.155.188
ip nat inside source static 192.168.5.189 135.112.155.189
ip nat inside source static 192.168.5.190 135.112.155.190
ip nat inside source static 192.168.5.191 135.112.155.191
ip nat inside source static 192.168.15.192 135.112.155.192
ip nat inside source static 192.168.15.193 135.112.155.193
ip nat inside source static 192.168.15.194 135.112.155.194
ip nat inside source static 192.168.5.195 135.112.155.195
ip nat inside source static 192.168.15.196 135.112.155.196
ip nat inside source static 192.168.15.197 135.112.155.197
ip nat inside source static 192.168.15.198 135.112.155.198
ip nat inside source static 192.168.5.199 135.112.155.199
ip nat inside source static 192.168.5.200 135.112.155.200
ip nat inside source static 192.168.5.201 135.112.155.201
ip nat inside source static 10.20.5.202 135.112.155.202
ip nat inside source static 192.168.5.203 135.112.155.203
ip nat inside source static 204.204.204.204 135.112.155.204
ip nat inside source static 192.168.5.205 135.112.155.205
ip nat inside source static 206.206.206.206 135.112.155.206
ip nat inside source static 10.20.5.207 135.112.155.207
ip nat inside source static 192.168.5.208 135.112.155.208
ip nat inside source static 192.168.5.209 135.112.155.209
ip nat inside source static 192.168.15.210 135.112.155.210
ip nat inside source static 192.168.15.211 135.112.155.211
ip nat inside source static 192.168.15.212 135.112.155.212
ip nat inside source static 192.168.15.213 135.112.155.213
ip nat inside source static 192.168.15.214 135.112.155.214
ip nat inside source static 192.168.15.215 135.112.155.215
ip nat inside source static 192.168.15.216 135.112.155.216
ip nat inside source static 192.168.15.217 135.112.155.217
ip nat inside source static 192.168.15.218 135.112.155.218
ip nat inside source static 192.168.15.219 135.112.155.219
ip nat inside source static 192.168.15.220 135.112.155.220
ip nat inside source static 192.168.15.221 135.112.155.221
ip nat inside source static 192.168.5.222 135.112.155.222
ip nat inside source static 192.168.0.223 135.112.155.223
ip nat inside source static 192.168.0.224 135.112.155.224
ip nat inside source static 192.168.5.225 135.112.155.225
ip nat inside source static 192.168.5.229 135.112.155.229
ip nat inside source static 192.168.5.230 135.112.155.230
ip nat inside source static 192.168.15.231 135.112.155.231
ip nat inside source static 192.168.15.232 135.112.155.232
ip nat inside source static 192.168.15.234 135.112.155.234
ip nat inside source static 192.168.0.236 135.112.155.236
ip nat inside source static 192.168.15.237 135.112.155.237
ip nat inside source static 192.168.15.238 135.112.155.238
ip nat inside source static 192.168.15.239 135.112.155.239
ip nat inside source static 192.168.15.240 135.112.155.240
ip nat inside source static 192.168.15.243 135.112.155.243
ip nat inside source static 192.168.15.244 135.112.155.244
ip nat inside source static 192.168.15.245 135.112.155.245
ip nat inside source static 192.168.15.246 135.112.155.246
ip nat inside source static 192.168.5.247 135.112.155.247
ip nat inside source static 192.168.5.250 135.112.155.250
ip nat inside source static 192.168.5.251 135.112.155.251
ip nat inside source static 192.168.2.102 135.112.251.102
ip nat inside source static 192.168.2.103 135.112.251.103
ip nat inside source static 192.168.2.104 135.112.251.104
ip nat inside source static 192.168.2.105 135.112.251.105
ip nat inside source static 192.168.2.106 135.112.251.106
ip nat inside source static 192.168.2.107 135.112.251.107
ip nat inside source static 192.168.2.108 135.112.251.108
ip nat inside source static 192.168.2.109 135.112.251.109
ip nat inside source static 192.168.2.111 135.112.251.111
ip nat inside source static 192.168.2.112 135.112.251.112
ip nat inside source static 192.168.2.113 135.112.251.113
ip nat inside source static 192.168.2.114 135.112.251.114
ip nat inside source static 192.168.2.115 135.112.251.115
ip nat inside source static 192.168.2.116 135.112.251.116
ip nat inside source static 192.168.2.117 135.112.251.117
ip nat inside source static 192.168.2.118 135.112.251.118
ip nat inside source static 192.168.2.121 135.112.251.121
ip nat inside source static 192.168.2.122 135.112.251.122
ip nat inside source static 192.168.2.123 135.112.251.123
ip nat inside source static 192.168.2.124 135.112.251.124
ip nat inside source static 192.168.2.125 135.112.251.125
ip nat inside source static 192.168.2.126 135.112.251.126
ip nat inside source static 192.168.2.129 135.112.251.129
ip nat inside source static 192.168.2.130 135.112.251.130
ip nat inside source static 192.168.2.131 135.112.251.131
ip nat inside source static 192.168.2.132 135.112.251.132
ip nat inside source static 192.168.2.133 135.112.251.133
ip nat inside source static 192.168.2.134 135.112.251.134
ip nat inside source static 192.168.2.135 135.112.251.135
ip nat inside source static 192.168.2.136 135.112.251.136
ip nat inside source static 192.168.2.137 135.112.251.137
ip nat inside source static 192.168.2.138 135.112.251.138
ip nat inside source static 192.168.2.140 135.112.251.140
ip nat inside source static 192.168.2.141 135.112.251.141
ip nat inside source static 192.168.2.142 135.112.251.142
ip nat inside source static 192.168.2.143 135.112.251.143
ip nat inside source static 192.168.2.144 135.112.251.144
ip nat inside source static 192.168.2.148 135.112.251.148
ip nat inside source static 192.168.2.149 135.112.251.149
ip nat inside source static 10.20.2.151 135.112.251.151
ip nat inside source static 10.20.5.152 135.112.251.152
ip nat inside source static 10.20.2.153 135.112.251.153
ip nat inside source static 10.20.2.154 135.112.251.154
ip nat inside source static 192.168.2.155 135.112.251.155
ip nat inside source static 10.20.2.156 135.112.251.156
ip nat inside source static 10.20.2.157 135.112.251.157
ip nat inside source static 10.20.2.158 135.112.251.158
ip nat inside source static 192.168.2.160 135.112.251.160
ip nat inside source static 10.20.2.161 135.112.251.161
ip nat inside source static 10.20.2.162 135.112.251.162
ip nat inside source static 10.20.2.163 135.112.251.163
ip nat inside source static 192.168.2.164 135.112.251.164
ip nat inside source static 192.168.2.165 135.112.251.165
ip nat inside source static 192.168.2.166 135.112.251.166
ip nat inside source static 192.168.2.167 135.112.251.167
ip nat inside source static 192.168.2.168 135.112.251.168
ip nat inside source static 10.28.2.169 135.112.251.169
ip nat inside source static 192.168.2.170 135.112.251.170
ip nat inside source static 192.168.2.171 135.112.251.171
ip nat inside source static 192.168.2.173 135.112.251.173
ip nat inside source static 192.168.2.174 135.112.251.174
ip nat inside source static 192.168.2.175 135.112.251.175
ip nat inside source static 192.168.2.176 135.112.251.176
ip nat inside source static 192.168.2.177 135.112.251.177
ip nat inside source static 192.168.2.178 135.112.251.178
ip nat inside source static 10.20.2.179 135.112.251.179
ip nat inside source static 10.20.2.180 135.112.251.180
ip nat inside source static 192.168.2.181 135.112.251.181
ip nat inside source static 192.168.2.184 135.112.251.184
ip nat inside source static 192.168.2.188 135.112.251.188
ip nat inside source static 192.168.2.189 135.112.251.189
ip nat inside source static 10.20.2.190 135.112.251.190
ip nat inside source static 192.168.2.191 135.112.251.191
ip nat inside source static 10.20.2.193 135.112.251.193
ip nat inside source static 192.168.2.195 135.112.251.195
ip nat inside source static 10.20.2.196 135.112.251.196
ip nat inside source static 192.168.2.197 135.112.251.197
ip nat inside source static 192.168.2.198 135.112.251.198
ip nat inside source static 192.168.2.201 135.112.251.201
ip nat inside source static 192.168.2.202 135.112.251.202
ip nat inside source static 192.168.2.205 135.112.251.205
ip nat inside source static 192.168.2.206 135.112.251.206
ip nat inside source static 192.168.2.207 135.112.251.207
ip nat inside source static 192.168.2.208 135.112.251.208
ip nat inside source static 192.168.2.209 135.112.251.209
ip nat inside source static 192.168.2.211 135.112.251.211
ip nat inside source static 192.168.2.212 135.112.251.212
ip nat inside source static 192.168.2.231 135.112.251.231
ip nat inside source static 192.168.2.232 135.112.251.232
ip nat inside source static 192.168.2.248 135.112.251.248
ip nat inside source static 192.168.2.249 135.112.251.249
ip route 0.0.0.0 0.0.0.0 135.112.155.1
access-list 1 permit 192.168.0.0 0.16.255.255
control-plane
privilege exec level 7 ip
privilege exec level 7 show running-config
line con 0
 login local
 transport preferred none
line aux 0
line 2
 login local
 no activation-character
 no exec
 transport input all
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 access-class 23 in
 privilege level 15
 login local
 transport preferred ssh
 transport input telnet ssh
line vty 5 15
 access-class 23 in
 privilege level 15
 login local
scheduler allocate 20000 1000
end
pss2900#
0 Replies 0
