09-24-2013 04:20 PM - edited 03-10-2019 08:55 PM
I have an older SBR appliance w/ version 5.43 and some Cisco Catalyst switches w/ 12.2.25 to 53 . Trying to get authorization to work via Radius. Basic config is:
aaa new-model
aaa group server radius RADIUS
server <ip> auth-port 1645 acct-port 1646
aaa authentication login default group RADIUS local
aaa authentication login loginauth local
aaa authorization exec default group RADIUS if-authenticated
radius-server host <ip> auth-port 1645 acct-port 1646
radius-server source-ports 1645-1646
radius-server timeout 2
radius-server key <snip>
Steel Belted is setup with a group that has:
cisco-AVPAIR shell:priv-lvl=15
cisco-AVPAIR Service-Type=login
When I try to login I get:
Username: kenny.sallee
Password:
% Authorization failed.
debug:
000860: 49w2d: tty2 AAA/AUTHOR/EXEC (3084441039): Port='tty2' list='' service=EXEC
000861: 49w2d: AAA/AUTHOR/EXEC: tty2 (3084441039) user='kenny.sallee'
000862: 49w2d: tty2 AAA/AUTHOR/EXEC (3084441039): send AV service=shell
000863: 49w2d: tty2 AAA/AUTHOR/EXEC (3084441039): send AV cmd*
000864: 49w2d: tty2 AAA/AUTHOR/EXEC (3084441039): found list "default"
000865: 49w2d: tty2 AAA/AUTHOR/EXEC (3084441039): Method=RADIUS (radius)
000866: 49w2d: AAA/AUTHOR (3084441039): Post authorization status = FAIL
000867: 49w2d: AAA/AUTHOR/EXEC: Authorization FAILED
LmUt-c3560-Tower-RM(config)#
000868: 49w2d: AAA/MEMORY: free_user (0x27000E8) user='kenny.sallee' ruser='NULL' port='tty2' rem_addr='1.2.250.219' authen_type=ASCII service=LOGIN priv=1
What I expect to happen is user gets authenticated at priviledge level 15 (and when I get this working - going to define priviledge level 1 users). This works for some devices - but not others (seems to be older versions of code where it does not work)..
If I change this
to
aaa authorization exec default if-authenticated
I can at least get authorized via SSH/Telnet - however, all logins are w/ privi level 1 (vs 15 coming from the radius server)
Any pointers?
09-24-2013 07:53 PM
On the steel Belted radius server, what have you selected under model/make?
Also, please replace the Service-Type=login with Service-Type=Administrative on the radius server.
Run the following debugs and test the authentication again:
debug radius
debug aaa authen
debug aaa authorization
Let me know how it goes.
~BR
Jatin Katyal
**Do rate helpful posts**
