06-26-2013 09:44 PM - edited 03-10-2019 08:35 PM
We are currently using Cisco ACS 5.3 integrated with Active Directory for authentication to our Cisco devices. We are looking to move to smart card logins and trying to find out if this is possible to authenticate to the console/ssh on the router/switch using a smart card.
06-26-2013 11:15 PM
As per my knowledge you cannot do that, it is not possible to authenticate an user logging into router console using a smart card. Router doesnt support that token based access control.
06-27-2013 05:40 AM
Direct Smart card authentication is not supported for vty / console session on IOS. However, via TACACS to a AAA server (e.g. Cisco ACS) you can turn it to use a two factor-based external authentication store. Even if the Smart card get the PKI cert of some kind to the client PC and then to the terminal emulator like Putty or SecureCRT, AAA with Tacacs + would not be possible as Tacacs is not capable for encapsulating any kind of PKI.
Jatin Katyal
- Do rate helpful posts -
