web authentication as a fallback method for Cisco ISE
mjrmontemayor
Please help to share how to configure wired dot1x fallback to web authentication. I could not find any documentation how to configure the ise to do the web authentication. for my switchport i configured this:
switchport mode access
switchport access vlan 135
ip access-group PREAUTH in
authentication event fail action next-method
authentication host-mode multi-auth
authentication open
authentication order dot1x web
authentication priority dot1x web
authentication port-control auto
authentication violation restrict
dot1x fallback WEB_FALLBACK
dot1x max-reauth-req 1
dot1x pae authenticator
spanning-tree portfast
spanning-tree bpduguard enable
ip access-list extended PREAUTH
permit udp any eq bootpc any eq bootps
permit icmp any any
permit tcp any host 172.21.2.82 eq www
ip admission name WEB_ADMISSION proxy http
fallback profile WEB_FALLBACK
ip admission WEB_ADMISSION
Please advice how to configure the ISE to make the fallback successful.
regards,
Mike
mohanak
Try this Configuration Process
The following example shows a WebAuth fallback profile:
  ip admission name IP_ADMIN_RULE proxy http
  ip access-list extended PRE_WEBAUTH_POLICY
   permit udp any any eq bootps
  permit udp any any eq domain
  fallback profile WEB_AUTH_PROFILE
  ip access-group PRE_WEBAUTH_POLICY in
  ip admission IP_ADMIN_RULE
The following example shows all the required elements of a configuration for IEEE 802.1X with WebAuth fallback in the order they would appear in the command-line interface (CLI):
aaa new-model
aaa authentication dot1x default group radius
aaa authentication login default group radius
aaa authorization network default group radius
aaa authorization auth-proxy default group radius
aaa accounting dot1x default start-stop group radius
aaa accounting auth-proxy default start-stop group radius
ip device tracking
dot1x system-auth-control
      interface Gigabit 1/0/5
switchport access vlan 30
authentication fallback WEB_AUTH_PROFILE
dot1x pae-authenticator
dot1x tx-period 5
ip http server
ip http secure-server
permit udp any any eq domain!
     radius-server host 10.100.10.117 key cisco123
     radius-server vsa send authentication
http://www.cisco.com/c/en/us/products/collateral/ios-nx-os-software/identity-based-networking-services/app_note_c27-577494.html
