05-15-2019 04:00 AM
Hello
I am configuring WLC access thru ISE. I see some options
If I select 'Monitor', the raw view is role1=MONITOR, similarly Lobby's raw view is... role1=Lobby
I have a requirement, the end user should have both the rules, how is this possible?
Can I do something like, add role1 and role2 in views as Monitor and Lobby?
Solved! Go to Solution.
05-15-2019 04:56 AM
It looks mutually exclusive so you would need separate accounts for them.
Configuring TACACS+ on the ACS mentioned,
05-15-2019 04:56 AM
05-15-2019 05:51 AM
Thank you.
