Access RemoteApp and Desktop Connection for RD Web
Not applicable
Will subsequent version of Duo support Access RemoteApp and Desktop Connection URL?
We have deployed Duo authentication for RD Web server. However, your website shows that if RD Web is installed, Duo authentication disables the use of RemoteApp and Desktop Connections URL.
Amy2
Level 5
Level 5
Hi @LiSen2010, great question! I understand you’d like to allow remote application launch with RemoteApp and Desktop Connections while using Duo Authentication for RD Web. As you’ve noted, this is not supported today and will likely not be supported in the future. Your options to protect remote logons with MFA are to:
  1. Install Duo Authentication for RD Gateway on your RD Gateway server to protect remote logons with MFA when launching applications published via RemoteApp feeds.
  2. Use Duo Authentication for Windows Logon and RDP to protect remote desktop logons.
I hope that answers your question and provides some good alternative solutions for you to consider.
