Protecting Applications
Duo helps you reduce risks by setting and enforcing policies and app access.
Navigation banner_4
Hello, We are working on enabling phish resistance with our Duo MFA. From what I can tell, for Duo Mobile users, that relies on proximity verification. Great, so I enabled that and have it working. But it doesn't work/apply to the Windows logon MFA a...
doGlooPA by Level 3
  • 1932 Views
  • 8 replies
Welcome to the Cisco Community Ask Me Anything conversation. Submit your questions from Tuesday March 31, 2026 through Wednesday April 8, 2026. Your Experts Namita Bhurke, Bahaa Saleem, Aaron Wolff, Wes Miller, Sheila Vida, and Derrick Sison will be ...
Hi, I followed the procedure that explains how to setup Duo for Fortigate’s SSL VPN as i was told that it should work for IPSec VPN connections also. Everything works as expected but the problem is that the connection still works even before i receiv...
GDumaresq by Community Member
  • 5920 Views
  • 8 replies
I have set up duo for unix on several ubuntu 20, 22 and 24 machines.  On all machines, the "pamtester -v ssh myname authenticate" command triggers a push, then follows up with prompt for password (as expected.)On some machines, ssh only requires a pa...
Tamerlane by Community Member
  • 1224 Views
  • 3 replies
