Disable duo for local logins
mikerino
Hi, I am using duo to protect RDP. Is there a way to disable it for local logins?
Welcome to Duo mikerino and canderson!
In addition to this open Community site and our public documentation, we also have a great public knowledge base full of answers like this one!
Can Duo protect Remote Desktop Connection logons only?
Be sure to check it out, and thanks for trying Duo!
Duo, not DUO.
candersen
There is a check box when you install duo on your server. I haven’t seen a way to change this after install so you may have to uninstall and install it again.
Duo, not DUO.
